Garden Logo
Posted on Jan 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where do i find the aquatak 110 plus manual to download
Anonymous
Level 3:
Master:
  • Master 411 Answers
  • Posted on Jan 18, 2011
Anonymous
Master
Level 3:
Master:
Answers
411
Questions
0
Helped
109367
Points
1240
Type in your browser aquatak 110 plus manual
I want to know capacity and specifications of yellow box capistor present in input supply of my Bosch aquatak 10 pressure washer?
Weight: The Aquatak 10 weighs 6000 grams, ensuring stability during use.
Maximum Pressure: Unfortunately, the specific capacity of the yellow box capacitor in the input supply is not explicitly mentioned in the available manuals. However, I recommend referring to the official user manual for detailed technical information.
Motor Power: The motor power of the Aquatak 10 is 1500 W.
Maximum Flow Rate: The maximum flow rate is 350 liters per hour.
Inlet Water Temperature: The pressure washer can handle inlet water temperatures up to 40°C.
Detergent System: It features a high-pressure foam detergent system.
Pump Type: The pump is a 3-cylinder all-metal pump.
Cable Length: The power cable is 5 meters long.
Hose Length: The hose length is also 5 meters (made of PVC).
Nozzles: It comes with a fixed fan jet nozzle.
Regarding the oil leak issue you mentioned, it's essential to address it promptly. Here are some general steps:
Turn off the pressure washer and disconnect it from the power source.
Inspect for visible damage or loose parts.
If you suspect a broken bearing, consider contacting a professional technician for assistance.
For the oil leak, I recommend not attempting to fix it yourself. Contact a qualified technician to address the problem.
Please note that the Aquatak 10 is an electric pressure washer and does not require oil replacement, as it does not have an oil reservoir. If you need further assistance, consider reaching out to Bosch's customer support or a certified tech.
2answers
Motor smokes
clean water filter out, not enough water coming out to cool the motor
Bosch aquatak 1200 plus
2 from the power cable and 2 that goes to the commutator circuit of the motor inbetween is the switch placed there can be a capacitor parrallell placed on the wires for suppression on the commutator side.
Apr 14, 2014 • Hammering
Bosch aquatak power washer will not start
Check to make sure the outlet (power supply) is energized. This piece of equipment is supposed to be used on a ground-fault protected circuit, so make sure the ground-fault on the outlet didn't trip or the circuit breaker (fuse) at the electric panel did not trip (or blow)
Check to make sure you are going through the proper starting procedures as outlined in your user's manual on page 8.
Follow the troubleshooting tips on page 10 of the user's manual.
Beyond that, Bosch requires that you have your power washer repaired at an authorized / qualified repair center.
I did locate a web site that shows an exploded parts view of the pressure washer, if that helps. http://www.magic-parts.co.uk/acatalog/BOSCH-Aquatak-1200-Plus.php
In case you don't have a user's manual, you can view it at: http://www.manualslib.com/manual/537062/Bosch-Aquatak-110.html#manual
Best wishes on your project.
A blockage in the inlet of an aquatak 115 plus.
nothing to worry about could be due to water intake,wear on nozzle or just the gauge
Top Garden Experts
Jay Finke
Jay Finke
john h
