Washing Machines Logo
Anonymous Posted on Jan 18, 2011
Water won't stop running in machine - Whirlpool Washing Machines
tom weber
Level 2:
  • Expert 198 Answers
  • Posted on Jan 18, 2011
tom weber
Expert
Level 2:
Answers
198
Questions
6
Helped
109520
Points
452
Replace water inlet valve on machine
Testimonial: "thank's for the tip, you are right on the money"
  • Anonymous Mar 19, 2011
    Is the water running from a hole right next to the light on top of the rubber seal?
  • tom weber Mar 21, 2011
    Glad to help you out.
Blinking blue light on water reservoir won't stop blinking
Needle port is plugged. Clean with paperclip end and run it up 1/4 into the tank to clear the debris.
1helpful
My samsung top loader washing machine sw65v9w won't stop filling with water
If the water stops when you stop the cycle, then the pressure sensor is at fault. If you need to turn the water supply off to stop it, then the water inlet valve is at fault.
2answers
Won't stop running water
does it over fill or does the water just keeps running in if it does the stand pipe is to low and needs lifting should be i meter from the ground
1helpful
Coffee water won't flow
You probably have hard water deposits in the tubing. Run a couple tanks of vinegar through the machine on a brew cycle. Then flush with a couple tanks of water.
1helpful
Water won't stop filling the washer
water fill valve is probably stuck open. see if you can find a blockage or just replace it
Ge prodigy top loader wash machine. washes fine, spins, but water won't drain. have checked for blockage in hose and found none. water will trickle through hose then stop. what do I do? Don't...
Water will not drain from machine
1. Kinked or clogged drain hose---clean hose
2. Pump does not run----readjust & tighten pump, drive mechanism
3. Suds lock---remove suds add cold water
4. Faulty transfer value---replace
5. Defective timer---replace
6. Loose belt----adjust belt
1helpful
Em-200iHR. after starting brewing, it stops and starts beeping. won't run full cycle. tried purging water. no success. happens intermittently
Try pouring a solution of equal parts of white vinegar and water into the machine and let it cook for a while. Several times through the machine will dissolve any calcium and coffee build up and "may" correct the situation. Note this is also the way to clean coffee percolaters and steam irons
2answers
The washer is ovrtflowing with water. It does not stop
Hi
Thanks for using FixYa. Overfilling in your washer occurs mainly due to two things: water inlet valve going bad and/or the water level switch. If the water inlet valve has gone bad it won’t be able to shut off even when the electricity has been turned off. If the issue is with the water level switch then it won’t tell the water to shut off and the machine will overflow as this switch is to sense the water level in the clothes tub. However, with that being said it seems that you’ll need to replace the water inlet valve. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Water won`t stop filling tub
if it's still filling when machine is switched off then water valve needs replacing.if it only overfills when machine is running the pressure pot could be blocked or the hose to the pressure switch could be split or the pressure switch might need replacing
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
