Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Keeps giving me the F1 signal. Whats the deal?
  • 552 Answers
this means the control needs to be replaced to fix the issue.
You can watch a video by clicking on the link below.
http://www.appliancerepairlesson.com/2011/02/23/cabrio-bravos-oasis-f1-error-washer-repair/
Posted on Mar 06, 2011
  • 198 Answers
Fellow, Academy of Sublime Masters of Appliantology
Joined: Sun Oct 7th, 2007 Location: South Carolina USA Posts: 6784 Flavorite Brew: waffle house coffee Status: Offlinespacer.gif F1 usually means a communication or an electrical error.
Unpgug the machine for 1 minute and then power back up. If fault reoccurrs check all connectors.
How long have you had this machine? Has it always been plugged into the same outlet? Is is sharing an outlets with another device?
Read more: Whirlpool Cabrio F1 code - The Laundry Appliance Repair Forum - Do-It-Yourself Appliance Repair Help - ApplianceGuru.com: The Samurai Appliance Repair Forums http://applianceguru.com/forum2/15527.html#ixzz1BPYo9agm
Get appliance parts at http://parts.fixitnow.com
Posted on Jan 18, 2011
6ya staff
SOURCE:
My whirlpool CABRIO washer is constantly giving me F1. I can hit the cancel button 4 different times and it will finally work. The F1 comes up on almost types of washing.
f1 code on cabrio washer indicate control board sensing a pressure transducer signal water pressure sensor signal (water level pressure sensor signal taht is out range .u might have a problem with the hose that connect from washer tub to pressure switch . so if you dont know how to check it you migth want call a appliance repair tech are you can put your model number in google an they can show you a video on how to repair your washer. ok
Mar 22, 2018 | Whirlpool Washing Machines
Fuse keeps blowing
Hi Anonymous, you got to many things going on to give an educated guess with out being in front of the bike. Before you take it to your local dealer or reputable shop check to make sure battery connections are clean and tight especially the negative cable at both ends and your charging system. Voltage at battery should be 14.3-14.7 volts at 3600 RPM. Good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jan 24, 2014 | Harley Davidson Motorcycles
F1 Error Code : Kenmore Self-Clean Electric Range. Oven wont shut off. I can silence the F1 alert but it keeps coming right back on every 30 to 60 seconds or so. Range top burners work fine, but oven
An F1 error code usually means that the temperature probe isn't sending the correct signal back to the control board. Try disconnecting power to the range for at least a minute. If F1 displays after you cycle power you may need to replace the EOC (Electronic Oven Control).
Dec 05, 2012 | Ovens
F1 code on my 05 suzuki gsxr 750
I HAVE A 2005 GSXR 750 AND WHEN IM AT HIGH RPM THE BIKE SHUTS OFF. DOES THIS HAVE ANYTHING TO DO WITH THE FI CODE BLINKING? BUT THERE ARE DAYS WHEN IT RIDES FINE....WIERD
May 13, 2012 | 2005 Suzuki GSX-R 750
My whirlpool cabrio washing machine keeps giving me an F1 ERROR when it goes to the rinse cycle. It will complete the wash after i hit cancel reset and wash. Any ideas?
F1(F68)-Pressure Signal Out-of-Range
I telephoned Whirlpool at 1-800-253-1301. Whirlpool acknowledged the F1 fault and will send a serviceman, free parts and labor, to correct the problem concerning the "famous" F1 fault. This is even for washers out of warranty! This concerns model WTW6600SW2 washers. Be sure to get the authorization code from them so the service person cannot argue about costs.
Jan 05, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Beeper keeps going off at odd times flashing F1 signal and wol,nt be clearec
Hi dorothymedwa,
F1 error description is a defective touch pad or clock (ERC). Replace touch pad or clock (ERC). Touch pad is a more common problem.
Hope it helps.
Thank you for using FixYa.
Dec 04, 2010 | Magic Chef 31000 Gas Kitchen Range
What does F1 indicate? My oven seems stuck on Broiler and a signal keeps flashing F1 with beeping signal. What could be wrong?
F1 is a common failure on a lot of ge oven controllers. Although sometimes it is caused by a keypad failure. The test is to disconnect the keypad, power up the oven with the keypad unplugged ... see if you get an F1 ... may take a while ... 30 minutes or so. If you still get an F1 then the problem is with the oven control board. If so, we can repair the board for you.
Bruce
www.fixyourboard.com
May 10, 2010 | Kenmore 95822 / 95824 / 95829 Electric...
I get an F1 signal when I start the washer. I can get it to go away by switching what kind of load it is but it keeps coming back?
F1 means communication error, Unplug washer for 2 mins.. What might have caused this problem is a power glitch of some kind.
Jan 17, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Error Code
A error code F1-09 deals with the finisher of the copier. Have the bins gotten stuck or got something in it's way when moving up & down. I would turn the copier off and unplug the finisher from the copier, 1 screw holds connector in. Then I would turn it back ON and see if the code is gone, if so reconnect the finisher and you should be good to go...
Jun 11, 2009 | Sharp AR 201 Copier
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
271 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
