Question about LG 32LG30 32 in. LCD HDTV
I have a TV Type 32LD450N LG. It is possible to get a "Caed" to insert on the left side ( seen from the TV-front). What is the specification/Type/Model, and where can I by it.? (Not in Norway, but I have heard roumors that it is possible in Sweden. I have also heard that this makes it possible to record to a DVD recorder/player from a GET box HD, even when the signals which come through a GET digital box which normally will prevent you from any recording from the GET-box HD
6ya staff
SOURCE:
Anonymous
  • 763 Answers
SOURCE: TV CONNECTIONS
if your cables are not compatible or incorrect ends then try to buy an adaptor to fit to the right connectors. so you will be able to connect each ends.
CHARCOIS
Posted on Sep 16, 2008
Anonymous
SOURCE: I have an external DVD Recorder / Player attached
I have a LG tv set. When i press the tv/av button on the remote my tv shows av1, av2 earlier but now it is showing only av. So i am unable to watch my dvd player. Need help.
Posted on Jul 13, 2009
Anonymous
SOURCE: after I reformat my LG HDD video recorder to give me more space, it only clears a tiny portion. How do I clear the whole recorder? I am going to HDD format, and reformatting. Thanks
Do you mean it always shows 10Gb less space than the capacity of the drive. ie only shows 150Gb but you have a 160Gb drive? The reason for this is that it has 10Gb reserved for the buffer of the pause/rewind live TV.
Cheers,
Keith
Posted on Aug 07, 2009
maneng
manuel antonio
  • 15 Answers
SOURCE: 1. my DVD player won't recognise any DVD.
observe your dvd's spindle motor or measure it's resistance using a digital ohmmeter it should read ranging from 8ohms to 12ohms and also check your laser's flexible wire check also your sledge motor. If all these checks ok then your optical lens should be changed.
Posted on Oct 14, 2009
Victor Albright
  • 324 Answers
SOURCE: How to set up LG
First, please note that your LG 387H is capable only of tuning analog channels, not the digital ones...
The easiest way is to connect your recorder directly to your incoming cable, then connect the output of your recorder to the TV set. Depending on what your set has available, either connect the HDMI OUT to HDMI IN on your set (best picture), or the A/V OUT to your sets A/V IN. Leave your set on the input you have selected, and use your recorder to change channels.
Posted on Jan 30, 2011
Tip
How to backup cust in lg pop (lg gd510) cell phone.
Download lg utilities from the link provided below.<br /><br />http://www.mylgpop.com/index.php?action=dlattach;topic=827.0;attach=266<br /><br />Next, ensure your phone is switched <b><span>ON</span></b>, then remove your battery and SIM card (and memory card if you have one), and insert only your battery. This will turn off your phone, but don't turn it back on.<br />Now you must type exactly this into LG-Utils-0.4.2. It IS CasE sEnsETivE. "\" or "Backslash" can be found in between "Z" and "Shift (Up arrow)" on the bottom left of the keyboard.<br /><br />D [ENTER]<br />\ \. \ USB1 [ENTER]<br />C: \ GD510.flb [ENTER]<br />CUST [<span><b><span style="text-decoration: underline;">Don't press</span></b></span> ENTER]<br /><br />Plug the USB end of the cable into your computer, but <span><b><span style="text-decoration: underline;">NOT</span></b></span> the micro USB into the phone. Open up the small flap on the side of the phone that protects the micro USB. Press "ENTER" and QUICKLY insert the other end of the USB cable into your phone. Now wait for about 5 minutes.<br />After 5 Minutes, the program will come up with an error. As long as it has been about 5 minutes, this is normal. Once it has finished, you can disconnect your phone. Remove the battery again, and insert it. Turn your phone on.<br /><br /><b><span></span></b> Minimise LG-Utils-0.4.2, and go into "C Drive". You will now see a new file, called CUST.big. This should be 133MB in size. <span><b><span style="text-decoration: underline;">DO NOT DELETE THIS FILE!!!</span></b></span> You must make a backup copy of this file. Create a new folder anywhere on your computer, called "CUST Backup". Copy the CUST.big file, and paste it into your new folder. This may take a few moments.<br /><br />Thus the backup is taken.<br />
on Mar 04, 2011 | LG GD510 Cell Phone
LG DR4810 black and white lines at top left and side of Picture extending accross middle of picture window. How Do I remove these?
I think you should take it back, cause! defective laser pickup, or the video processor, and possibly the audio/video cable, "replace to be sure"
May 08, 2012 | LG DR-4810 DVD Recorder
Our Vizio VX42L has an audio problem. The sound is "scratchy." When I change the audio setting completely to the left side speaker, the noise goes away and the sound is fine out of that single...
Small component board that controls sound could be faulty. It is near the bottom of the tv and the size of about a quarter. Another possible cause is "shorting" due to assembly ...If the speaker wire comes in contact with the metal at any point you will get this type of noise. Either way, you will need to take your tv apart to truely tell if the board is bad, or the wire has been cut slightly.
Thank you and best of luck!~
Jun 16, 2011 | Vizio 42 in. LCD TV
I have a 2001 Jaguar S-Type V8. I drove my car on the highway for over an hour last night, with no problems. But when I was idle shortly there after, it began to over heat. Also when I do city driving...
A couple of possibilities. You should consider changing thermostat and coolant. Also fan belt that drives waterpump should be replaced, and lastly new radiator/coolant cap (they do loose ability to hold pressure)
Jan 02, 2011 | 2001 Jaguar S-Type
I have an LG 42" LCD tv with blurred image on half the screen
lg 42 in lcd tv power button blinks nine times before staying on and has sound but no picture
Feb 04, 2010 | LG 42LC2D 42 in. LCD HDTV
My S-type heater is not working. Blowing only cold air. Also, The temp gage goes from cold to max hot within five minutes of starting the car. Any ideas would be appreciated
Hi There
I have had the same problem, if the climate control shows different temps at either side it most possible that the heater valve needs replacing, the valves inside get rusty and sieze up, it is situated at the front o/s at the side of the radiator. If temps are the same could be the control module
Jan 14, 2010 | 2000 Jaguar S-Type
LG 2277 Liquid Detergent Box & Insert
please put detergent into the main(left) side of the dispenser
Feb 15, 2009 | LG WM-2277HW Front Load Washer
LG 32LG30 32 in. LCD HDTV Logo
239 people viewed this question
Ekse
RONALD CARTER JR
