I have the Turboion Croc Black NanoTitanium Flat Iron 1.5" and it seems that possibly the spring inside of it is broken causing the straightener to not be able to open and shut and then stay open. Anybody know how to fix this problem?? I believe the straightener has a 1 year warranty and have had it for only a few months. I bought it from Amazon, so not sure where to send it to get it fixed or get a new one. Please help!!!!!!
Error code 021 on a Turboion Croc Classic flat iron indicates a problem with the temperature sensor. This error can prevent the flat iron from heating up properly and may cause it to shut off unexpectedly.
To fix this issue, you can try the following steps:
Turn off the flat iron and unplug it from the power outlet.
Use a small screwdriver to open the back cover of the flat iron and locate the temperature sensor.
Carefully inspect the temperature sensor for any signs of damage, such as bent or broken wires, loose connections, or burnt components.
If you notice any damage to the temperature sensor, you will need to replace it with a new one. You can purchase a replacement temperature sensor from Turboion or from a third-party supplier.
Once you have installed the new temperature sensor, reassemble the flat iron and plug it in. Turn it on and check if the error code 021 is still appearing.
If the error code persists, you may need to contact Turboion customer support for further assistance. They will be able to provide you with more detailed troubleshooting steps and help you resolve the issue.
Nothing about definitive fixes, but people complaining about them and that the life span is only 2 years!
There is this though :>)
How do I reset my croc flat iron?
I've searched the net for the answer and how to reset croc flat irons is actually really simple: Turn it off at the wall and unplug it. Wait 10 seconds and turn it on again. Hold down the HIGH button for 5 seconds and then press the on/off button again.Oct 18, 2020
It's not working! I've tried unplugging it for a minute, plugging it back in and holding the power button on....am i missing something. I've had this damn thing for about 2 months. Please dont tell me i have to buy another one....AAAHHHHH!
