This toy does not charge even after days of charging. Charging base still blinks red instead of going steady green to show unit is fully charged. Can you help with this, please? My child is so disappointed.
Here's a guide;
What do the battery lights mean on my mouse?
Some keyboard and mouse models feature a battery light that shows the current status of the batteries. The following table describes the different lights and states.
Light
Device Model
Status
Single long green blink
Rechargeable
Batteries are good. This occurs when batteries are first installed or every time that the device is turned on.
Slow green blink
Rechargeable
Device is docked in the charging station and is charging properly.
Steady green
Rechargeable
Device is docked in the charging station and does not need additional charging.
Steady green
Presenter Mouse (Japanese version)
Laser pointer is on.
Red/green blink
Wireless
Device is discoverable (trying to connect to the transceiver).
Slow red blink
Non-rechargeable
Batteries are low and need to be replaced.
Slow red blink
Rechargeable
Batteries are low and need recharging.
Fast red blink
Rechargeable
Device is docked in the charging station, but there is a charging error. Reasons for errors: The wrong type of battery is installed; the battery or batteries are missing; or the battery connection is bad. Solutions: Make sure that the correct battery or batteries are installed, and are installed correctly. If necessary, remove the batteries, wipe them with a clean cloth, and reinsert them.
Steady red
Presenter Mouse (Standard version)
STATUS LIGHT will FLASH RED when charging. Allow at least 30 minutes for a full charge. STATUS LIGHT will turn ORANGE, and then turn off when charging is complete. STATUS LIGHT will FLASH GREEN when the batteries in the CHARGING BASE are LOW. Replace the batteries. STATUS LIGHT will FLASH RED & GREEN when there’s a CONNECTION ERROR. Reconnect the FAIRY.
the light on the front of the heli blinks green red green gred then when its fully charged it just blinks green. also make sure the tx is turn to the charge setting which is all the way down
Hi just got one myself and after a day same problem. Replace all your remote batteries with new ones And it will charge normally with blinking red then red and green blinking. I enjoyed flying it but enough is enough. There is no replacement blades, It eats batteries. I would go with this sites micros http://www.xheli.com/rchelicopter.html
Im looking at this one, charges with usb so wont kill batt's, Metal frame and also they sell parts http://www.xheli.com/s107-miniheli-blue.html. Good luck and happy flying.
According to the manual, the red light comes on while charging when the battery does not yet have enough charge to sustain a 3-5 minute shave. The green light stays on steady while the razor is charging, and blinks when it is fully charged. If your battery life is short, they might need to be changed.
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Red light slow blinking: Battery Low, please put mouse in charger and charge;
When in Charger Red light Slow Blinking: No charging, please check and clean Gold Plated contacts in charger and Mouse;
When in Charger green light Blinking: Charging in progress
When in Charger green light Steady: Charging complete
When in Charger Red light Fast Blinking: Mouse detects overvoltage during charging! Please clean Battery contact inside Mouse, or replace rechargable batteries NiMh 1500-2100 mAh only
