HI,
If your dryer doesn't work at all, it could be because of problems with:
Power from the house
Check
to see whether there's power getting to the dryer. Is it plugged in? If
you plug something else into the outlet, does it work? If not, check
for a blown fuse or tripped circuit breaker.
Door switch
If
the door switch or the door-switch actuator is defective, the dryer
won't work and you need to replace the failed component. The switch is
inside the dryer main housing near the door frame. Sometimes you need
to raise or open the top or front of the dryer to reach the switch.
Thermal fuse
On many dryers, there's a thermal fuse (a heat-sensitive fuse
that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an
inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your
dryer either just stops heating, or it doesn't work at all. Be sure to
inspect the venting/heating system before replacing the fuse to put the
dryer back into operation. (You can't re-set this type of fuse.)
Wiring
Often
the main wiring connection from the house, at the dryer, burns and the
connection breaks. In this has happened to your dryer, you need to
replace the power cord and the terminal block inside the dryer to which
the wire is attached.
