Posted on Jan 16, 2011
Kodak ESP 3250 Printer shows message "Unable to detect edge of paper" and paper just goes straight through
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 21, 2013
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
465
Points
0
If means anything, Joe Diaz's solution of taking the printer head out two times worked for me. I have AIO 3250 Printer
Anonymous
Level 1:
  • Posted on Apr 15, 2013
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
465
Points
0
I've had this problem with my esp 3250 that has become progressively worse over past year. I have tried every fix available online from driver, cleaning, power, etc. My printers default quality was set to 'draft' (just to save ink) which obviously speeds up the printing and I've found that if I use 'normal' or 'best' quality, it seems to help the printer detect paper edges, I think bc it slows down physical printing process? go figure but it's gotten me around a few times when I've needed hard copies immediately. Also, changing to heavier bond paper, 92 or better helped with edge detection. I'll finish current ink and not buy another one of these:(
5 Related Answers
Anonymous
  • 295 Answers
  • Posted on Jul 28, 2009
SOURCE: paper jam message on esp 7 kodak printer
open rear access door and check out if there is any tape in and around the rollers or any torn paper or any staples there.. turn printer upside down and oprn bottom p[aper tray check out if there is any paper stuck there. take power cord out of printer and again insert it back. ur printer will work fine
Anonymous
  • 1187 Answers
  • Posted on Sep 28, 2009
SOURCE: Printer says 'Unable to detect paper width'
The paper tray has some "fingers" that detect the paper.
Remove the paper and tap the sensors a few times to make sure they are not stuck.
Use lots of mamper, not just one sheet so that there is enough weight to press down on the sensors.
Perhaps it is Earth's gravity that is malfunctioning today :)
Anonymous
  • 185 Answers
  • Posted on Jan 30, 2010
SOURCE: Kodak ESP 3250 device driver failed to install
This down load should correct your problem. It is teh Kodak driver whiz. It will check your computer to correct any faulty drivers for Kodak devices.
http://driverwhiz.com/drivers-en?brand=Kodak&logo=Kodak&subid=1001-us-en-10000001283&gclid=CLCggv7-zJ8CFd1L5QodV0ah3g
Good Luck.
Anonymous
  • 35 Answers
  • Posted on Jul 26, 2010
SOURCE: purchased Kodak ESP 3250 yesterday. Not printing photographs.
Yes sounds to me like one of your ink cartridge is empty. Replace and try again.
Testimonial: "Hi - the printer was caput - had to be replaced. Thank you for help."
Joed911
JDTec
  • 4338 Answers
  • Posted on Jan 29, 2011
SOURCE: Kodak esp 3250 printer error.
To resolve the error condition:
1. Disconnect the power adapter from the printer.
2. Wait 30 seconds to allow the printer to reset.
3. Connect the power adapter to the printer. Turn the printer on if necessary.
4. Wait until the printer is ready to use.
If the error condition continues:
1. Open the printer access door.
2. Remove and install the print head two times. - See http://faqs.kodak.com/atg/faq/attachments/AUR1780-2.pdf
3. Close the printer access door.
5. If the error is still displayed, contact Kodak
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Paper will not go through printer and also crinkles when comes through the printer
When the paper does not feed straight, then dirty or stickyrollers can cause the paper to jamb or crinkle.
Try cleaning the rollers with methylated spirits
3helpful
2answers
I have a brand new Kodak ESP 3250. Not one drop of ink color or black, is coming out of the cartridge. And even so, the indicator shows a loss of ink. ! no spills inside. I am absolutely certain the...
Clean the gold section of the print cartridge's with a wet paper towel.
Also clean the gold surfaces where the cartridge meets the printer.
Wipe the contacts clean with a dry paper towel once you get no ink back on the wet paper towels. Allow about an hour for the printer to dry.
Reinstall the cartridges and try printing.
Hope This Helps.
Zeppelinx12
29helpful
2answers
My Kodak ESP 3250 won't scan. It just keeps telling me "Scan to computer failed"
Try initiating the scan from the computer, once you plug in the USB cable into your computer, go to My Computer, right click the sanner (should be called something along the lines of KODAK ESP.....) and press scan, then click which program you'll use to scan it, I usually do the Microsoft one, Good luck!!
7helpful
Kodak ESP 3250. Error 3527. I put new ink cartridges in.It started to pull the paper thru then stopped. I had to remove the paper buy pulling it back out. It says Printhead cartridge jam. Open printer...
Contact Kodak. I think it's the batch of printers that were made around this time. I just contacted them (mine is the same age and I'm getting the same error), and they are sending me a new printer.
PRINTER DOES NOT DETECT PAPER EDGE
Have you tried "fanning" the paper before loading it? This fixed my problem after a 6 hour battle, downloads of all firmware and restarting infinity times.
I put paper in align the guide, click on print. It doesn't print. It says it is unable to detect paper width.
Restart your printer,put 8.5X11 papers in th paper tray.Align the gray coloured paper tray to the edge of the paper.Place any paper on the scanner glass of the printer and press copy on the printer.You will get a copy from the printer. Keep posting me ...
4helpful
1helpful
MY ESP 5 PRINTER WILL NOT DETECT THE PAPERS EDGE.
Kodak printers support the following paper sizes: 3½ × 5 in. 4 × 6 in. 4 × 8 in. 4 × 12 in. 5 × 7 in. 6 × 9 in. 8 × 10 in. A4
Make sure that the grey coloured paper alignment is aligned properly to the edge of the paper.
turn your printer off and then turn it on again. put papers and align the paper alignment. try to print,your issue will be resolved.
k24674
ADMIN Andrew
ADMIN Andrew
