Write it down all the bios settings. and remove laptop keyboard by removing screws back side of the laptop (small embosed picture indication remove those screws) and just lift the keyboard and search for cmos battery, see below picture , just unplug the battery and keep unpluged for minuite or two. and connect the battery. fit all the opened cover and restart . best of luck
Hi,follow these carefully.but you'll have to open the system up,if you have no prior I.T expertise I'd suggest you take to a qualified Technician,but if you do here is how:First remove the Battery,then uncouple the system taking care to remember where each of the screws go to then locate the CMOS battery(small battery Lithium Ion mostly in the shape of a cent or smaller),it may be underneath the keyboard or just behind the outer back casing,once the external cover is open.unplug it from the system for about an hour or two reconnect it,couple the system and boot,go to Bios,reset Date and Time and save,then exit.
FOR IBM/LENOVO PASSWORD
Hello sir read these instruction. Solution for all IBM/Lenovo laptop
check this site... http://ja.axxs.net. you need to buy this device Key maker pro...
OR
there is one more way to break password for many laptop ..you need to made serial port or printer port and there is software for it ...
check this site http://www.lancos.com/prog.html Thanks
