Dryers Logo
Posted on Jan 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dryer starts for 4mins and then flashes up F09 fault. I have lost manual please can you help
Anonymous
Level 3:
Genius:
  • Master 1,637 Answers
  • Posted on Jan 11, 2011
Anonymous
Master
Level 3:
Genius:
Answers
1637
Questions
Helped
290310
Points
4933
Hello beth325, please tell me what your make and model number are for your dryer so that I may continue to provide you with free expert solutions.
Thank you for allowing us to help, please respond with further questions and concerns
Spanish speaking available for all problems
Before you leave feedback, ensure that your concerns and problems are addressed completely with me.
PLEASE do not forget to award/PROVIDE "POSITIVE" FEEDBACK
PROVIDING FEEDBACK WILL ALLOW US TO CONTINUE SUPPORTING YOU IN EXPERT SOLUTIONS Before you leave feedback, ensure that your concerns and problems are addressed completely with me.
Seimens E 46 38 F09 code
I welded the cable after cutting the wire inside the encoder but after running the machine , it displayed an error F09 in spindle control unit module.
having the F09 Fault, is it necessary to do a reset for Simodrive 611 to see if the fault no longer exists or not.
and if yes, how to reset the fault code f09 that is displayed
F-09 = Motor encoder system is faulty. Check motor encoder cable or motor encode
My Bosch Maxx6 Sensitive dryer starts and works for 4or5minutes than stops beeping,the light flashes and it shows F09 on her little screen.Than it doesn't work anymore in every program I can put it.What...
F09 means there is an issue with the thermostat and could be that the thermostat needs resetting. Isolate the machine from the power source before you attempt any repair on the machine.
You will have to gain access to the heater by removing the rear cover to reset the thermostat. The thermostat has a reset button which should be pressed and you should hear a click when it resets. Check that all filters are clear of any debris prior to refitting the rear panel, reconnect the power source and try the machine again.
Do not attempt any repair if you do not feel confident to do so. Call a service engineer
Sep 27, 2014 • Dryers
How to fix recurring F09 error in Bosch condensing dryer WTE86300US
How long is the connection including the duct work in the house?
Siemens condensing dryer - fault f09
I had the same problem on wt46s514by/24 have no reset button, however all were tested and seems to work properly. Done cleaning also, pump seems to work, it is still not heating and gives f09 and sometimes 0.
Indesit wd12 (old) timer just goes round without stopping. door light flashes 9 times, help!
Hi, this is the list of the Indesit wd12 error codes...
Error codes and their meaning..
f01 light 4, motor triac f02 light 3 motor, jammed/ tacho f03 lights 3&4 Ntc fault f04 light 2. pressure sw stuck on empty f05 lights 2&4, pressure sw stuck on full f06 lights 2&3, N/A? f07 lights 2&3&4 heater relay f08 light 1. heater relay f09 lights 1&4 eprom/setup error f10 lights 1&3, pressure switch not sensing f11 lights 1&3&4, pump/draining error f12 lights 1&2, communication error f13 lights 1&2&4, dryer ntc/ fan motor f14 lights 1&2&3, dryer heater f15 lights 1&2&3&4, dryer heater relay f16 N/A f17 light 4, door lock f18 light 3 comms error (3 phase motor) power board
Door flashing 9 times means 1&4 eprom/setup error
5helpful
My Hotpoint Aquarius WF430 1300 doesn't complete its cycle, it stops after the wash & doesn't go on to the rinse & final spin. It seems to "freeze" after the wash is finished as the lights remain...
If your lights are flashing, use these codes to pinpoint the error.
These codes are reading from the top neon down.
F01....OFF, OFF, OFF, Flash, OFF.
F02....OFF, OFF, Flash, OFF, OFF.
F03....OFF, OFF, Flash, Flash, OFF.
F04....OFF, Flash, OFF, OFF, OFF.
F05....OFF, Flash, OFF, Flash, OFF.
F06....OFF, Flash, Flash, OFF, OFF.
F07....OFF, Flash, Flash, Flash, OFF.
F08....Flash, OFF, OFF, OFF, OFF.
F09....Flash, OFF, OFF, Flash, OFF.
F10....Flash, OFF, Flash, OFF, OFF.
F11....Flash, OFF, Flash, Flash, OFF.
F12....Flash, Flash, OFF, OFF, OFF.
F13....Flash, Flash, OFF, Flash, OFF.
F14....Flash, Flash, Flash, OFF, OFF.
F15....Flash, Flash, Flash, Flash, OFF.
f16....OFF, OFF, OFF, OFF, Flash.
F17....OFF, OFF, OFF, Flash, Flash.
F18....OFF, OFF, ON, OFF, OFF. Fault on control board, check Eeprom.
these are the codes and this is what they mean
f16 N/A
also try checking this manual
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/WFseries_19504110305_Jan05_book.pdf
Hotpoint wf310 set wash,it starts then after about 20 seconds the on/of light and the lights to the far left flash
you will have to check the error code number which you get as per the blinks.
f16 N/A
ignore the on off light
as per the fault mentioned you will have to check the fault in your unit and then replace that following part in your unit.
you can get required parts from
www.repairclinic.com and also from www.partselect.com
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 27, 2009 • Dishwashers
2helpful
2answers
Fault code FO9
F09 means that it's running on the wrong power frequency.
Is this a model designed for a different country than the one you're using it in?
Does your owner's manual show a way to select a different power frequency?
If for some reason you don't have your owner's manual, see Panasonic.net for support.
Top Dryers Experts
john h
