You must put the alarm on a valet mode to see if the alarm is causing this problem
To enter or exit Valet Mode
1. Turn the ignition on
2. Turn the ignition off
3. Press and release the valet switch within 10 seconds
The status Led will light solidly if you are entering valet mode, and it will go out if you are exiting valet mode.
To enter or exit Valet Mode using the transmitter:
1. Open any vehicle door.
2. Press and realese lock and unlock buttons at the same time
3. Press and realese Aux button
4. Press and realese the lock and unlock button at the same time again
The status led will light solidly if you are entering Valet Mode and it will go out if you are exiting Valet Mode
Now when in Valet Mode try to start the engine, if the problem persist the alarm has nothing to do with it
Fig. Fig. 5: Remove the fuel filter/pressure regulator retaining clip from the top of the assembly
Fig. Fig. 6: Replace the old fuel filter/pressure regulator mounting gasket
Fig. Fig. 7: Check the condition of the fuel filter/pressure regulator O-rings
Locate the Fuel Filter and Fuel Pump
REMOVAL :-------
WARNING: THE FUEL SYSTEM IS UNDER A CONSTANT PRESSURE, EVEN WITH ENGINE OFF. BEFORE SERVICING THE FUEL FILTER/FUEL PRESSURE REGULATOR, THE FUEL SYSTEM PRESSURE MUST BE RELEASED.
INSTALLATION
Lightly lubricate the O-rings with engine oil.
Thanks.
keep updated for any more query.you can rate this solution and show your
appreciation.
