ASUS P4P800SE Motherboard Logo
Posted on Jan 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Shut down my PC, unplugged it, moved it to new location. Plugged it back in and it would not power up green light on the ASUS P4P800SE would not stay lite. Replaced power supply, green light on the mother board will now stay lite, but when the power button is pushed the three lights on the front tower will flash for a second and then go dim, green light on the motherboard remains green.
Anonymous
Level 3:
Genius:
  • Master 1,288 Answers
  • Posted on Jan 11, 2011
Anonymous
Master
Level 3:
Genius:
Answers
1288
Questions
Helped
285792
Points
4123
Remove cmos battery and then replace it after 3 mins or so,
Try rebooting
If no luck, remove ram modules one at a time and retest
unplug all but hdd and power connector to mobo, cpu and hard drive and retest.
failing that, could be a surge of electricity has damaged your mobo
Flashing red power light on Gateway 700X
try disconnecting the lower optical drive and rebooting...may just be a bad drive.
1helpful
WHEN I POWER UP ON MY ASUS P4P800SE Motherboard IT WONT START THE GREEN LIGHT ON MY Motherboard IS ON CPU/CHASSIE FANS COME ON BUT QUICKLY POWER DOWN
HI
it is a SMPS problem. SMPS is the main power supply it is also known as smart module power supply..
if you want to check try this link
if you find this is helpful for you so please rate me this will encourage me todo more free work..
regards'
sandy
2answers
I have a homemade system with a P4P800SE mobo. The system is about 3 years old and has worked great until the other day it wouldn't turn on. I tried the power switch and the reset button. Nothing. The...
there are many things that can shut down a motherboard.
power spikes, the caps on the board, a blown diode, voltage regulators alot of people use a power strip to protect there computers which is wrong they will not prevent a spike from getting to your hardware, even tho the light comes on the board (3.3v) if you do not have 12v or 5v getting through the board theres no way to get it to go the only thing you can do is see if you can find someone who fix's the boards or upgrade to a new mobo or find a replacment on ebay or one of the other sites
Shut off and won't come back. It's like it is dead.
follow this procedure:
1. unplug the ac adapter and keep it unplugged.
2. Remove the battery and keep the battery unplugged.
3. Hold the power button down for 15-20 seconds(Nothing will appear on the display and none of the lights will light up)
4. Release the power button and plug in the ac adapter ONLY. (A power indicator light should be lit on the ac adapter when it is plugged in)
5. Normally power on the notebook.
6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
7. Plug the ac adapter back into the system, the battery charging indicator light will light up. If the battery indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
Char S.
Blinking Green LED on Dell Dim. 2350 won't let system stay on.
once check the ram and keep it in other slot and check it .clean the ram and keep it
Compaq presario sr1115cl wont power up
dont u dare ever use 220 line on thes eon usa power u blow it ever time u turn it on at 220 v dont u dare do that not no reset switch erther u must now buy new power supllly ok
Green light flashing after shutting down computer to relocate office.
if its by the power button the led just indicates power after u have removed its source and reconnected it........this is normal nothing to worry about.
Remove the power supply after everything is unplugged and take it to your nearest electronics store. They should have a tester there. This is probably the problem.
Wont post.
Try a few things for me OK? From what you typed, turned on the psu "the toggle switch on the psu", pc seemed to be starting up. I need you to keep the toggle switch on the power supply in the on position. Press and hold the start button on the PC case to shut it down. Give it a few seconds & power up by pressing the power switch on the case. Notice a differance? Next, unplug everything connected to the pc expect the monitor, mouse & keyboard. Try to boot. Still no? Remove the side of the case exposing the board. Turn the psu off by flipping the toggle switch on the psu, wait till the green light on the board goes out. Grab the Mb ( I know it's tight in there) and see if you can move the board in any direction. Not loose? Re-check all data & power connections for a solid connect. Re-check your case to Mb connections. Also check the PSU, there is a red slide switch it should be set to 115v. Post your findings..
map
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
