SOURCE: when I sharpen my chain with the timber tuff
I will wager if you place a protractor on the bar you will find the right and left links are at slightly different angles (one side gets more bite). It only takes a little difference. The usual suspect is the guide on your sharpener. Some grinders require an offset because the wheel is offset more to one side than the other.
I hope you found this helpful.
Lou
I would say yes. Set the tilt first, then the angle.
Check out some YouTube videos showing how to sharpen chains.
Good luck
