Kobian Hip Street  Digital Media Player Logo
Posted on Jan 10, 2011
I plugd in my mp3 and it did nothing my computer shows when i have one plugd in but i plugd this one in and it did not show and i cant put songs in it.
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Aug 16, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
794
Points
Once attached to computer open file "my computer" attach an mp3 file to each drive. disconnect hipstreet. re-attach hipstreet once again.
once again open "my computer". by clicking on each drive seperately
you with see the "drive" with the mp3 file on it. this is the drive which
hipstreet is linked to.
note: when you wish to remove all songs, leave one track remaining
such that you won't have this problem again!
My mp3 player wont play songs
dear try to update your mp3 software version their may be that you paste 2 songs in same name post. then your mp3 player stuck on it and showing nothing
2helpful
2answers
I cant play my mp3 on my Usb stereo
make sure that when you put your songs to your thumbdrive that they dont get compressed,,, sometimes when your putting songs on them they will automatically compress, which would cause some work and the ones compressed to only work on a computer
E250 SANSA MP3 - IVE NEVER DOWNLOADED MP3 FILES BEFORE....
I have this player and it drives me crazy, too.
I don't know if this will help delete what you don't want but plug the sandisk into your computer and open to view the contents. when you see the list of folders, at the top click on tools--then folder options--then view make sure "show hidden files and folders" is checked. click ok. then if you can see the folder you want to delete, highlight it and press the delete key on your keyboard. (if you want to save it, copy it to your hard drive instead). to put on a cd this may be a roundabout way but is fairly simple. put the cd in the computer, using windows media player rip it and save songs in a folder on the hard drive. save as mp3 (or wma should work, too.) you can read on the net how to do this. once the songs are in the folder, close media play. go to the folder and the hard drive and copy it to the sandisk . you can see on your computer if it is there. unplug from the computer and hopefully you can find it and play the songs. good luck!
Deleting songs
If this problem occurs then your ML648B needs to be formatted.
1. Connect your ML648B to your computer with Windows XP or later.
2. By default your computer will recognize ML648B as GPX MTP Device. Press the POWER button from top of your ML648B, to change it to USB mode connection. You will also see USB on the screen of ML648B.
3. ML648B will now mount 2 drives, one as Tools (as CD-Drive) and second as Removable Disk (Drive) – under My Computer on your Windows Desktop.
4. Right click your mouse and then select the Format option. When the Format Removable Disk window appears select the Start button to start formatting your MP3 player.
MY computer cant detect sansa clip n i cant hear any songs...Plz help me as soon as possible
make sure it's plugged up to both the computer and mp3 player first, then if nothing automatically pops up, click on computer and there should be a picture of your mp3 player, which is it, if nothing is showing you may have a faulty plug. =] let me know.
Hiphone mp3
what that means is that some of the songs are formated different and the player cant interface with the format. i have a phone with a mp3 player intergrated to it all the songs will play on the phone , but i take it and put in my other dvd/mp3 player and all the songs play except for 2 i figured it out the 2 songs are formated different. so the only way to fix this problem is go on your computer and re download the formated songs like the 15 that work. please rate this
Cant add songs after i made space
Have u checked if the songs u put in have extensions that are supported by the player............in ur case check if some of the songs are .rm or something and not .mp3...........only files with .mp3 extensions will be supported
1helpful
3answers
Delete songs
You should be able to hook your mp3 player up to your computer with the USB cable. This will allow you to browser the directory where the songs are and delete or add new songs. Your mp3 player will appear in your computer as a removable disk. The songs that you put on your mp3 player need to be in mp3 or wma format. I also found the instruction manual for your product in pdf format. http://www.gpx.com/shop_ind.php?id=%20%20344#
2answers
Uses memory,but doesnt show up
Don't buy another Sansa Product. I'm not.
Top Kobian Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Kobian Audio Player and Recorder Expert? Answer questions, earn points and help others
