Question about Bosch WFLI 2440 Front Load Washer
SOURCE: Bosch Maxx WFL 2260
Hey check to see if you can move the drum by hand,, if you cant the the bearings on the drum have gone and it is seized ..
If you can turn it by hand then most likely it is the carbon brushes on the motor..
hope this helps
any questions dont hesitate to contact me im here to help....
Posted on Jan 17, 2008
SOURCE: Bosch wfl 2450
Just fixed the same problem - new brushes on ebay were only £5. Fitting the brushes was fiddly and easiest if you take the motor off, which was easy to do (just 2 bolts).
Posted on Sep 05, 2008
SOURCE: changing brushes on motor of Bosch WFL 2450 washing machine
Remove rear panel of washer, and undo 2 screws that secure the motor, lever motor back with a screwdriver or similar, and unplug motor lead.
Be sure to keep hold of the motor so it does not drop on the floor.
You will see the brushes at the terminal end of motor, remove and replace.
Plz rate my solution.
Thanks.
Posted on Jan 05, 2009
SOURCE: bosch maxx wfl 1300 washing machine that wont start.
hello could be brushes on the motor. there are 2 black clips that sit on the motor after time these whare down just slide them out and slide new ones in good luck
shaun
Posted on Jul 21, 2009
SOURCE: Bosch Maxx WFL 2450 Washing machine Electric fault
hi there ...it sounds as the watyer leak has found its way into the motor windings and damaged the motor..and the control module.....could be a very expensive repair
regards Sir Galahad
Posted on Aug 18, 2009
Feb 13, 2015 | Bosch Washing Machines
Aug 21, 2014 | Bosch Washing Machines
Jan 09, 2018 | Bosch Washing Machines
Oct 15, 2013 | Bosch Axxis WFL 2060 Front Load Washer
Jan 17, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Dec 08, 2009 | Washing Machines
Aug 18, 2009 | Washing Machines
Apr 01, 2009 | Bosch Washing Machines
Jun 01, 2008 | Bosch Classixx WFL 2462 Front Load Washer
Mar 10, 2007 | Bosch Axxis WFL 2060 Front Load Washer
206 people viewed this question
