The 3010 24v JD system is not a true 24v system. It is a balanced split 12v system, with one positive ground battery and one negative ground battery. The only 24 volt accessory is the starter, where the batteries meet in a series to provide 24 volts for starting. All other accessories are 12v, half powered by the positive ground battery and half powered by the negative battery. The generator charges one battery in one direction and the other battery in the reverse direction. Therefore a 24v alternator is not easily adapted to this system.
The usual solution is to change to a 12v system with an alternator, changing the starter to 12v and changing the polarity of the positive ground battery to negative ground.
The cost of a 12v starter and alternator is far less than the cost of a 24v alternator, plus the added benefit of using 12v lights and other accessories.
JD switched to this 12v type of system with alternator during the 20 series production, but used two 6v batteries in a series due to the larger cranking amp rating of the 6v batteries occupying the same physical space.
