Question about Ryobi Thickness Planer Blades
Where can I get new blades for ryobi ah115 planer jointer 12 inch blades
Click on the link below to order a replacement set of 12" blades for your Ryobi AH115
http://www.amazon.com/PLANER-BLADE-SET-AH115-RYOBI/dp/B000P8QN8U
Posted on Jan 10, 2011
  • marchese969 Feb 12, 2011
    I went to this link on amazon. there is no picture but the package description is 5x5x5 and 12 llbs. that doesn't sound like 12" planer blades to me....
  • Anonymous Feb 12, 2011
    These are the correct planer blades, match the model number up to what it says in the link "AH115"
How to change blades on 12 inch Planer
Google search your manufacturer make and model and the word
manual. If one is available, you can find it in the search
results. The manual will provide instructions on how to change the planer blades.
Mar 17, 2015 | Masonry Tools
Ryobi AP1301 planer. Suddenly started getting ripples in wood.parallel to blades. Tried reversing blades to unused side, made no difference.Only trying to take of about 1/16". Stock is...
CHECK THE ROLLERS THAT PULL THE WOOD THRU, I HAD TO REPLACE MINE FOR THE SAME REASON.
IF THEY HAVE A LOT OF USE YOU WILL SEE WORN FLAT SPOTS ON THE ROLLERS CAUSING THIS PROBLEM
Jan 16, 2011 | Ryobi Thickness Planer Blades
How to change blades in delta 12" planer
http://powertool.manualsonline.com/manuals/mfg/delta/tp300.html
Sep 24, 2010 | Delta TP300 Shopmaster 12-Inch Portable...
Which way does the beveled edge of the planer blade face when they are being installed.
when standing at the back of the planer you should be able to see the beveled edge, the flat side of the blade should be facing the front of the planer.
Jul 06, 2010 | Delta TP300 Shopmaster 12-Inch Portable...
How to replace drive belt on ryobi thicknessor
How to change belt on a ap10 thickness planer
May 09, 2010 | Ryobi Thickness Planer Blades
How to change blade
I replaced blades on my planer and now the wood is getting chatter on it, why?
Jan 09, 2010 | Delta TP300 Shopmaster 12-Inch Portable...
I have a 12 5/16'' ryobi planer and need a place to get a set of knives and books.
go to home depot and purchase DELTA 12 1/2 inch blades. make sure they are centered so they don't rub the sides of the housing or grind off a little bit off each end.
Oct 18, 2009 | Ryobi Thickness Planer Blades
Ryobie ap 1301 surface planer
Here is the Ryobie support web site . You may still be able to get the manual for your service planer.
https://register.ryobitools.com/customer_session/new
Dec 22, 2008 | Ryobi Thickness Planer Blades
Ryobi Thickness Planer Blades Logo
808 people viewed this question
Top Ryobi Masonry Tools Experts
Thomas F. Schneider
ray gallant
Paula Hamilton
Are you a Ryobi Masonry Tool Expert? Answer questions, earn points and help others
