Forgot Windows 7 Password?
The video is really helpful!
You can create a Windows password reset bootable CD/DVD or USB flash drive to reset forgotten Windows password, i have created a bootable USB flash drive with the tool Windows Password Breaker and reset my administrator password successfully.
If you forgot the eee pc 701SD password, you can no heasite to use the SmartKey Windows Password Recovery 6.0 from http://www.recoverlostpassword.com/products/windowspasswordrecovery.html
Use windows installation disk to reset lost windows administrator password.read the following post to get that method. http://goo.gl/gNMts
I know a simple way to reset windows password. Download a software on the internet and reset or remove the password with it. Yesterday, I also lost I windows 7 password, finally I reset it with Windows Password Seeker I think it is the easiest and safest way for resetting windows password. http://www.passwordseeker.com/howtouse.html
I believe probably the easiest and safest way for you is remove your Windows OS Passwords with Windows Password Recovery tools. I found a good one at http://www.reset-windows-password.com/how-to-reset-windows-password.html last week, and then I downloaded it and used it to remove the lost password within only few minutes. Furthermore, the powerful tool didn't cause a little data lose. It's worth an attempt.
You can log on as administrator on safe mode.Press F8 when you start the computer and choose Safe Mode to get in.If you can not log in safe mode, try the tool bellow,it is the best method without lose anything.
In consideration of remaining all programs and data of the computer,I recomend you to use a passowrd tool:Windows Password Rescuer.It supports all versions of windows operation system.Recover Windows password without lose anything.Here are the simple guide:
Step 1: Download Windows Password Rescuer Personal and install it in any available computer
Step 2: Burn a bootable CD/DVD or USB flash drive
Step 3: BIOS settings of your locked computer to make it boot from CD/DVD or USB flash drive
Step 4: Reset Windows password successfully.
You also can use Windows Password Rescuer to add a new user with administrator privilege to your Windows when you can not find target user. With this New user account you can logon your locked computer directly to copy important data from the locked computer if you want to reinstall your Windows system at last.
http://www.daossoft.com/documents/quick-start-guide-for-using-windows-password-rescuer.html
Lost windows os password is just not a serious problem. I realize a simple solution to reset lost windows passwords, only need to create a bootable CD/DVD or Usb memory card to reset lost windows password, I have made a bootable CD with the program Windows Password Reset 9.0 and reset my administrator password successfully.
I didn't remember my Windows logon password, a week ago. Finally, my workmate Louis advised Windows Password Seeker. This powerful program assist me access to windows successfully. You can Search windows password seeker or just go to their official site: http://www.passwordseeker.com
Once you forgot windows password, you can bypass windows password with third-party password reset tools, take Windows Login recovery for Example, it is professional software woking for windows password reset. You can download it and follow its guide to burn a password reset CD/DVD or USB falsh drive to get your password reset or bypassed.
SOURCE: forgotten password on ASUS Eee pc 701sd can i do
1.) Try removing the CMOS battery & check
2.) Get the Bios flashed
The CMOS Battery thingy works most of the time.
try pressing ESC 2 or 3 times to bypass this option. Then go to your user account settings and change or delete your password. If all else fails, format HD or burn a bootable windows password recovery program and boot up pc with the disc.
SOURCE: i forgot the password to my 701sd eee pc please
Sometimes the only user who has Administrator previliges is the Administrator, this being said did you know that you should try creating another Administrator account and simply delete the old one,. It will at first seem that you did not do anything because you will still see the other administrator until you attempt your save and restart...then presto you should be good. This worked for me on a tower but if it's xp or vista you should be good..hope it helps!!
