I have a model WTL 5410 electric condensation dryer. There is water on the floor under the back. Any idea where I might start looking to find the problem. Have checked the hose for cracks, none found. Have cleaned vent. could there be a pump clogged,
Check and make sure the drain hose in the back is securely connected from the dryer to the drain. If its leaving out the front compartment by the heat exchanger, then you need a new drain pump.
Open the bottom front panel. Remove the heat exchanger. Take notice to see if theres any water in that compartment. Reach your hand towards the back of that opening to see if there is water pooling back there. If theres water present, then your condensation pump needs to be replaced.
also double check the connection of the drain hose from the dryer to the drain.
Check your lint filter first, and then try to restart it. Also, make sure the door is completely shut. If this doesn't do it, check your condensation hose for blockage. These dryers are very sensitive to lint build up, so make sure to change your lint trap after each load. It's not only a good practice, but it's necessary with this machine
