I received this error message and I don't know what it means? HELP
Bosch E04 Solution:
Okay, the solution is easy, I used the answer from a sears washer with the same problem. UNPLUG the washer. The little round door on the front comes off by taking a small instrument and pushing the hole, I used a small allen wrench and pushing in on the hole while at the same time twisting the cover, it pops right off. Inside there is a cap about 4 inches across that you rotate counterclockwise while running a wet vac with a crevice tool next to the pipe. Don't take it all the way off as the water will go everywhere. Let the water out gradually while using the vac to ensure it doesn't fill the bottom of the washer. Once the trickle eases you can remove the cap entirely and pull it out. Reach in with your fingers and you can fell the impeller which will probably have something laying around it. Mine was 6 hairpins from my daughters and a guitar pick from the same. Screw the cap back on tight and then put the cover on. Plug the machine in and cycle it to spin. Push the button, in about 20 seconds it should start spinning. While the problem was small and easy to fix I found the lack of good information provided in the manual to fix it yourself extremely poor.
Supposedly the fix for this is to turn off the washer and then re-run the 'spin' or the 'drain' cycle. good luck.
SUDS OR PUMP BLOCKED - ACCORDING TO THE MANUAL
I have the same problem but the machine won't run the spin or drain, it sits and just goes back to the error after a few minutes. I need a new solution!@
I opened the little round door, opened the black drain cap and drained out the water, but now there is a white cap that is in the way. How do I get this off?
I did all this, found a few hair pins, put it all back together. Now the washer cycles electronically, but wont drain, spin or anything. Just makes a humming sound! At least I was able to get my beautiful thanksgiving tablecloth OUT of the washer but its ruined having sat in there so long the colors ran!!!!!!! I hate this washer
