I followed what Bob Newell posted and it worked. i had the same problem with the TV not wanting to turn on. after i installed the update it works fine and turns on every try.
to install the update you have to turn the TV on so keep trying till it does. took me about 20 tries pushing the front panel power button, once it powers on the install will auto start and just let it do its thing.
My sylvania 32 LC320SL1 HDTV tv will not turn on it stays in standby and when I click the power button the power light flash around ten times then the screen flashes on and says digital television in the bottom right then goes back into standby its make a click sound as it goes from power on to standy by
I had this exact problem. I went to the Sylvania website and found a firmware upgrade for my TV. The Sylvania site provides detailed instructions with illustrations. This worked for me and fixed the problem.
Please follow the instructions exactly and if you are not tech savvy, ask a knowledgeable friend to help. You should not attempt to upgrade firmware unless you have confidence in your ability to do so. You *could* end up with a completely dead TV if you mess it up.
SOURCE: my Sylvania TV LC320Sl1 will
lori2scott...did you ever solve your problem? Mine is now doing he same thing and I dont know what to do. Thx pwest17
