Check out My Video on how to replace Oster 76 Switch at Mannys-Sharpening.com Service You can Trust Since 1990
Hope this helps, this is a tongue guide, you hopefully recognise it on your blade. If they are not paralell, then adjust them with pliers, both need to be perfectly vertical. When you put it on the clippers push the latch in as you close the hinge.
If it still wobbles then the next fe wthings need checking
1. The hinge screws on the clipper are tight, located either side of the hinge on the clipper.
2. The drive lever may be worn, thats the maroon peice of plastic sticking up at the top of the clippers, it moves from side to side when clippers are running.
3. If all seems fine up to now, your clipper should be fixed under warranty as it will involve changing parts covered by the warranty.
www.sheareaseltd.com
SOURCE: How to connect one speed toggle switch on oster
e-mail [email protected] he will show you how with photo instruction. he ask for a donation for the cancer for women month
