Disconnect first the mains, power plug off the wall. You could have a clog in your soap drawer; pull the dispenser drawer completely out. There is a tab that needs to be depressed to release the drawer to remove. Clean the soap drawer with an old tooth brush. The usual block could be old soap, softener, etc. (you could also be using too much soap powder). I usually use just above 125ml (my measure cup says ml, I use front loader powder for the 5.5kg load) The wash is very gud. This is the normal issue that will cause water to leak out of the dispenser housing. Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Next could be one of hoses has become loose, should be re-fixed. Examine by removing top of the front loader; this will give you a gud view of the pipes.If helped, click.
Hello. Most likely your water inlet valve is the problem. If you are mechanically inclined you can change this yourself. That said, if your machine is less than two years old it is still under warranty. If so, call for service at Sears.com Regards, Joe
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub. Pull the dispenser drawer completely out. There is a tab that needs to be depressed to release the drawer and remove it. Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening. Reach down into this opening to see if an item is inside the hose. This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
run a cup of vinegar thru a wash cycle, put it in like soap. i have also seen people use scolding hot water in the dispenser to disolve the soap and softner build up.
there is a spring around door opening that holds bellows on remove it and pull back from inlet opening also possible if you use dry detergent a lump has become lodged in fill line working something from both ends may dislodge it
I have the same problem. Can't get soap out my clothes. I have a Sears Kenmore frontload washer. It seems to work fine but something isn't right. Repair man came few days ago & said NOT to use the brands they say "For ALL HE Washers" ALL being the key word. Only use the ones that only say HE. I changed back to Gain instead of Sam's brand, but I still can't get soap out. I really don't think its the detergent. I washed my daughters towels & had soap in clothes after complete full wash was done. I'm lost & have no idea what the problem is or how long its being going on before I noticed.
