Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
if its a spark plug ignition, check if there is a tiny spark to ground, remove fan 1st. also remove rubber line on the left side of the motor. If you get only a tiny weak or no spark, the trans former is shot unless it has a bad ground where it mounts under the motor. that spark should arc at least 3/8 of an inch when good.
