Cars & Trucks Logo
Anonymous Posted on Jan 05, 2011
I bought a 1996 Subaru Impreza L 4dr 5speed AWD that runs and starts fine but when I was installing fog lights i noticed that there appears to be an alarm hooked up (it says "code alarm elite DM 1500") and the siren is cut but still in the engine. Anyways I was wondering if I could get an install manual or something so I could check the wiring and make sure its all connected. Also i was going to put a remote start in the car, any hints or thoughts on that or the alarm code?
Anonymous
Level 2:
Scholar:
  • Expert 146 Answers
  • Posted on Jan 05, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
146
Questions
0
Helped
54433
Points
471
Battery Constant 12v+ Positive Wire (+): Black/Yellow
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Blue/Red
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Red
Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Red/Yellow
Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Positive Wire (+): Red
Parking Light Positive Wire Location: Low In Drivers Kick Panel
Power Door Lock Negative Wire (-): Add Actuator. This vehicle uses a central door locking system. When connecting a keyless entry, you will need to add a door lock actuator and some units will also require (2) extra relays.
Power Door Lock Negative Wire Location: To Drivers Door Only
Power Door Unlock Negative Wire (-): Add Actuator. This vehicle uses a central door locking system. When connecting a keyless entry, you will need to add a door lock actuator and some units will also require (2) extra relays.
Power Door Unlock Negative Wire Location: To Drivers Door Only
Door Trigger Negative Wire (-): Red/White
Door Trigger Negative Wire Location: In Black Plug, Above Hood Release
Domelight Supervision Wire: Use Door Trigger, Requires Relay
Domelight Supervision Wire Location: N/A
Horn Negative Wire (-): Red/Green
Horn Negative Wire Location: At Steering Column Harness
Tachometer Wire Negative Wire (-): Black/Blue
Tachometer Wire Negative Wire Location: At ECM, Under Drivers Side Dash
Brake Light Positive Wire (+): White/Black
Brake Light Positive Wire Location: At Switch Above Brake Pedal
CODE ALARM SYSTEM
Used on:
Impreza 1996-2001
Legacy 1995-1999
Forester 1998-2000
I bought a 1996 Subaru - codealarmremote2.jpgBattery GP-23A
Lock: Left button will lock all doors. Double chirp indicates locked.
Unlock: Right button will unlock driver's door only. Hold unlock button app 6 seconds, it will unlock all doors including rear gate. Single chirp indicated unlock.
If the car chirps or lights flash 4x the alarm was triggered.
Panic. Press both buttons to activate emergency honk and flashing lights.
Valet mode: With optional alarm onlyPress the red alarm button on the left of the steering wheel. The light will quickly double flash. To re-set back to normal mode, press the red alarm light button again
Battery failed and lights flashing?
Parking lights will flash when the vehicle's battery is disconnected and reconnected.
To stop lights from flashing, either:
Press remote transmitter "UNLOCK" button once OR turn the ignition switch to the "ON" position and press programming button for one second (see below).
The vehicle interior (courtesy) light and door open warning light (DOOR AJAR indicator) will then illuminate for 60 seconds when the ignition is turned off, or until the doors are locked with the remote transmitter. Yes, the dashboard instrument panel lights will flash when the parking lights flash.
Programming or Overriding the Alarm when you have lost the remote
Open driver's door.
Turn ignition key to 'On'
Press and *hold programming button* in (see diagram, button under dashboard)
After 15 seconds the the door locks will cycle 3 times. Do not release Programming button.
Press lock (left) button the remotes to be programmed. The door locks will cycle one time. Exit programming mode by releasing Programming button under dashboard and turning key to off.
Code Alarm Programming Button is under dashboard on the kick panel by the driver's left knee, left of the steering column. If you can't find it, it might still be tucked up in the wiring harness higher up in that same general area. The botton is recessed in a plastic ring (see diagram).
This button must be pressed while programming remotes or if the battery was disconnected and the lights are flashing.
  • Anonymous Jan 05, 2011
    http://www.keylessentryonline.com has your remote as i am sure many other places will as well
Error code troubleshooting
It's your AVCS/cam shaft issue, bring the dealership since this issue is on Subaru TSB. Possible they replace the ECU/ECM unit.
02-132-12R Technical Service Bulletin Diagnosis and Repair for AVCS-Related DTCs P000A, P000B, P000C, P000D, P0011, P0014, P0021 and P0024
Need a diagram for 5speed awd 1995 subaru impreza
ts0gc8xorqqgdfv6j89tb3oaku2ds8d302vdrrlxktjwl4pjc5kuzk+xepnynnpzcfqljikiwmmb2x81nyuhctf9hhnzn26z7eknwc3sqsb+ibrjuatle1zxvogwvwvb+fahdokf4qgh3v0wacep5+czjg7janzs3ceq9fd09pq48c+h8aqmn915lv0loaaaaasuvork5cyii=
this is an a standard manual transmission. just giving you an idea what it is. CVs to make standard(2WDs) to be AWD or 4WD.
1helpful
Timeing
Doesn't matter what engine it is as long as it has valves and uses petrol (not diesel), the camshaft lobes at cylinder #1 should always face upwards. This positions the valves at it's closed setting (combustion), this is known as Top Dead Center or TDC. With this in position, all your timing markers should align on their marks (cam pulley, crankshaft pulley or flywheel ring gear). Do not confuse yourself with other cylinders being this and that, as long as number 1 cylinder is at TDC or 0* you have set your timing correctly.
Pls. give this a rating, thank you.
I have a 2.2l 1995 subaru impreza l awd. It won't
sounds like the starter again...was the first one warrenty'd?
Which fuse is for mirrors for subaru impreza 1998 - 1.5l ?
1998 Impreza L Coupe, L Sedan, L Sport Wagon, RS Coupe AWD, 2.2 or 2.5 engine, need to know to help with
2answers
Car starts up runs for a little bit and shuts off an wont start
it could be overheating either cooling system or a electronic piece .
are you getting a check engine light ?
Top Subaru Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Oliver Street
Are you a Subaru Expert? Answer questions, earn points and help others
