On the intake 0.0008 or 0.0020 (it's in between these 2)
this is for the stem to guide clearance. (for the intake)
The Exhaust 0.0018 to 0.0030 stem to guide clearance.
Could you give me the exact tappet clearance suzuki 3 cylinder 12 valve
Tappet clearance is a space between the top of the stem of the valve and the rocker arm when the valves are closed position & the engine is in compression stroke.
tappet clearance would not be same for inlet and exhaust valve It depends on manufacture.
There is effect on combustion and performance of engine when there is change in value of tappet clearance.
you can read about tappet clearance link is given below.
https://marinerspoint.in/tappet-clearance/
this topic is very important because questions directly asked in interview.
was after the valve to rocker arm clearances or valve lash or tappet clearance thanks anyway
cold valve clearance for 96 1.3 suzuki swift
