I had the same error and I could find no information on what it was or how to fix it so I decided to go trial and error. What I found is that this relates to the print head not being able to completely pass from the left to right side during startup. I had a plastic carriage on the one side that was stuck in a position that stop the carriage from make the complete run from side to side. When I forced the plastic carriage down and it clicked into place the error stopped and the printer started up normally with no codes. If anything is causing the print head to not travel completely from left to right during startup, this will probable cause the code. It will be hard to see if the print head is being obstructed if you don't remove the sides. I hope this helps.
SOURCE: my pictures are coming out rosey color looking
try to set the resolution of your epson, to picture quality or something like that.also you have to identify if the picture you are printing is same or big as the papar you are using, its possible that is in the picture it self.hope it help, :)
