Well the good news is that the door is open and not locked closed --- do not close the door until the problem is for sure fixed. on the inside of the door there should be a access panel that is held on by some screws,, remove the screws and panel. now depending on the make and model of the safe there are a few things that could have happened here. there is a chance that a re-locker has failed and jammed the linkages from moving. ( NOTE : the dial should not turn until the handle is in the locked position ). now if you look at the bolt linkages ( top,bottom,and sides ) make sure that none of the bolts have jammed up against the exit holes of the metal of the door. lubricate all linkages using a silicone or teflon based lubricant. the next thing to check is to make sure that the bolt from the combo pack is not broken and jamming up the handle linkage. there are not many things that can go wrong with the safe -- it is all just a bunch of levers and linkages and it has been my experience ( working as a locksmith for 18 years ) that this problem is a binding issue. again,, I cannot stress it enough to make sure you do not close the door until the issue is fixed and you have tried the combo several times and simulated a open and close ( handle lock and un-lock ) test.
if after all this you are still having issues - it is well worth the service call to have a locksmith stop by and service the safe, this will insure that the safe does not lock you out.
c...
