All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater Logo
Posted on Jan 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need a new fan motor where do i get one - All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater
Anonymous
Level 3:
  • Master 674 Answers
  • Posted on Jan 04, 2011
Anonymous
Master
Level 3:
Answers
674
Questions
0
Helped
284354
Points
1926
You can get them at Grainger but they will have to order.
New fan motor gets hot and stops after an hour have new computer
Sounds wired wrong, possibly wrong wires on capacitor.(if there is one of course) need to have wuring schematics and make sure its wired right. Hopefully its the right motor!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Where is fan motor relay located?
Search Results
    Chrysler Cooling Fan Relay - YouTube
    ? 5:00
    https://www.youtube.com/watch?v=AdIYm9kM5E0
    Jan 9, 2010 - Uploaded by realfixesrealfast
    Review the electrical diagram before you begin and this should help ... ... How To Solve An Engine Overheat Condition - EricTheCarGuy - Duration: 26:09. by ... 1999 Dodge Caravan AWD 3.8L Radiator Fan Relay Replacement for ... Terms · Privacy · Policy & Safety · Send feedback · Try something new!
    Need to find location of cooling fan motor relay - Fixya
    www.fixya.com/cars/t26003541-need_find_location_cooling_fan_motor
    4 hours ago - need to find location of cooling fan motor relay - Chrysler 1996 New Yorker question.
    Guess no-one knows where the fan motor relay is. Not ...
    images for 1996 chrysler new yorker wiring
Radiator fan/coast to fix
An hour or two labor cost plus the cost of a new fan motor, and the shop's mark-up for the fan motor. If diagnosing of the fan circuit is called for, expect to pay more.
Save the labor costs and price of new motor by doing it yourself with a whole fan assembly from a salvage yard. Very easy to remove and replace. However, if it is not the motor at fault but a circuit fault, you will have to diagnose or pay for diagnostics, but with a known good fan motor, would be considerably less. The computer energizes the radiator fan relay to shoot power to the fan motor when needed.
NEED NEW MOTOR OR FIX MOTOR ON A 20" PEDESTAL FAN
It would probably be cheaper to just buy a new fan.
Air is cold. Compressor outside works. The condensor will run for a little while, then shut off while compressor is still running.
Outdoor condensing fan motor has stopped running. This problem could be caused by a bad motor run capacitor. purchase a new capacitor. If your motor capacitor is not the problem, then more than likely you need a new motor. Is the fan blade tight, stiff or hard to turn? If the fan blade is hard to turn then you probably need a new motor.bobicehouse_96.jpg
Air conditioner fan will not turn on outside. Rudd model# UPKA-025JAZ
Outdoor condensing fan motor has stopped running. This problem could be caused by a bad motor run capacitor. bobicehouse_41.jpg
3answers
Kenmore model 3639550610. Ice maker motor and freezer fan motor wont stop. Need to find wiring diagram.
If fridge repair because it is noisy, turning off and on, or running all the time, it could be a sign the condenser fan motor is going bad. Thankfully, this type of repair is not as complicated as some may think. You can check the condenser fan motor yourself and replace it if necessary.
Tools and Materials Needed:
* Multitester
* Screwdriver
* Needlenose pliers
Step 1 - Disconnect the Power
Turn off the power to the refrigerator to prevent electric shock.
Step 2 - Remove the Condenser Fan Motor
The condenser fan motor is located on the bottom of the fridge, most likely toward the back. Heat from inside the fridge is released into the air here. A panel will probably need to be removed to access the motor. Depending on the screw, a screwdriver or nut driver will be required to remove the panel. Find the condenser fan and motor. You can quickly check the fan's operation by seeing if anything is obstructing its rotation. Manually move the fan blades to see if they spin freely. If they do not, you may need to replace the fan. Continue removing the condenser fan motor by taking out the screws that affix it to the mounting bracket.
Step 3 - Test the Condenser Motor
Your condenser fan motor will most likely have 3 wires attached. Some models have just 2. Note which wires are connected from the fan to the motor. Use needle-nose pliers to remove the wire connectors from the motor. Be careful not to damage the wires. After the connectors are removed, use the multitester to check the resistance or passage of electrical current. Set your multitester to ohms.
If the condenser motor has 3 terminals, only the outside terminals need to be checked. The inside one is a ground terminal. Check the terminals by using the multitester probes, touching one probe to one terminal and the other probe to the other terminal. The reading should fall between 0 and infinity. If you reading falls on either 0 or infinity, then the condenser motor is bad and will need to be replaced.
Step 4 - Replacing the Condenser Motor
Condenser fan motors can be ordered from the refrigerator's manufacturer. Once you receive the new motor, check it with your multimeter the same way as the old motor. This will make sure the new motor is in working condition. Attach the wire connectors to the new motor in the identical locations as the old one. You can refer to the new motor's wiring diagram (most likely included with it) if assistance is needed. Now install the new motor under the fridge. Attach it to the mounting bracket using the same screws as before.
Step 5 - Testing the New Motor and Keeping it Efficient
With the new motor connected and attached, turn the power back on. The unit should operate correctly. If it does not come on, check the wiring. Dust and dirt can plug a condenser and affect the fan's ability to discharge heat. Cleaning them several times a year will help the fridge run efficiently.
Hope this help in solving.take care....
1helpful
3answers
Replace old attic fan motor, or replace the entire fan assembly.
I am assuming you replaced your fan by now. However in the future call Gibraltar Industries, they are the ones who manufacture all fans and motors. My attic motor fan also died and I first called Ventamatic and they wanted $65 for a new motor. I then called Gibraltar and they shipped one our for free. 800-527-1924.
Fan motor not working
Hey, I need to buy a new fan motor and will share the install info once I install it myself. My question is: Where can I buy a fan motor for this unit?????
1helpful
2answers
Need replacement motor for Ventamatic Attic Fan
common motor. get from butler ventamatic or Johnstone Supply if you have an account. Hint, buy a whole new fan for $60; cheaper then buying piece by piece, then you get a new blade,motor and tstat for a little more then motor alone costs.
Top All-Pro Heating & Cooling Experts
Paul Carew
john h
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
