Refrigerators Logo
Posted on Dec 28, 2010
My wine ref, is not cooling, i can hear it running but it just dont cool. this is the everstar wine refergerator Model number HDBC361D
David Mayhall
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on May 04, 2015
David Mayhall
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
730
Points
22
I HAVE ONE OF THESE COOLERS I HAVE REPAIRED MY UNIT BY CAREFULLY PULLING OUT EACH EVAP COIL AND SANDING THE RUSTY AREA AROUND THE SOLDER CONNECTIONS AND SOLDERING THEM WITH A PROPANE TORCH GLAZING THE LINES WITH SILVER SOLDER AND FLUX. THEN AROUND ON THE BACK OF THE UNIT IT HAS 2 VALVES THAT CONTROL THE FREON GAS FLOW/ CUT THE COPPER LINES THAT GO TO THE 2 VALVES AND CAREFULLY BEND THE TUBING AND RESOLDER THE TWO LINES BACK TOGETHER WITH A HOMEMADE COPPER TUBING , BY ROLLING COPPER AROUND A SCREWDRIVER FASHIONING A TUBE TO CONNECT THE PIPES TOGETHER, RESOLDER THE PIPES SO THE FREON WILL NOW FLOW FREELY INTO EACH COIL. THEN RECHARGE THE UNIT WITH A CAN OF PAG 1 OUNCE OIL AND 2 OUNCES OF FREON 134A. RUN UNIT TEST FOR LEAKS WITH A SPAY BOTTLE AND SOAP WATER. YOU CAN OBTAIN A SADDLE VALVE FOR RECHARGING REFRIGERATORS AND INSTALL IT ON THE COMPRESSOR TUBE THAT IS COMING OUT OF THE COMPRESSOR AND IS WELDED SHUT BY FACTORY WHEN BUILT. CHAR4GE THE UNIT WITH 3.75 OUNCES OF 134A AND 1 OUNCE OF PAG OIL TO REPLENISH COMPRESSOR OIL FROM DISCHARGEING UNIT! REPAIR AS DIRECTED AND BOTH SIDES WILL REACH A 36 DEGREES. THE UNIT WILL NOW COOL TO 36 AND SHUT OFF BOTH SIDES ARE NOW WORKING AS 1 UNIT AND COOLING EFFICENTLY. THE VALVES GET STUCK AND WONT ALLOW FREON TO PASS THEN 1 VALVE LEAKS AND THE OTHER WONT OPEN. THIS IS A COMMON PROBLEM WITH THIS UNIT THIS IS THE BEST AND CHEAPEST REPAIR BY DAVID MAYHALL. [email protected] THE FIXIT MAN! LOCATED IN ALTON ILLNOIS ELECTRONIX SALES & SERVICE 3120 E BROADWAY ALTON IL 62002 PHONE 618-433-1815
  • The Dude
    The Dude May 04, 2015
    Damn dude, so much detail, thanks!
5 Related Answers
Anonymous
  • 87 Answers
  • Posted on Aug 26, 2007
SOURCE: U-Line no longer cooling
This sounds like the thermostat is the problem. I wouldsuggest touching the compressor at the back of the unit to see if it is hot or cold. If it is hot then you have probably have power down to the compressor, if it is cold you could (if capable) bypass the thermostat to see if it kicks in. Hope this helps.
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Nov 10, 2008
SOURCE: maytag refmodel number mff2557hew
sounds as if perhaps the fan in the freezer is not circulating air up to refrig sect. pretty common issue, if you pull out freezer door youll be able to hear the fan on the back wall, behind the vent on top sect of freezer. that cover pops right off with a pry of the screw driver.. heres the part number if indded that is the issue 12002744 comes with instuctions on how to install
Anonymous
  • 86 Answers
  • Posted on Jul 27, 2009
SOURCE: Wine Cooler Doesn't work anymore
All cooler have a condensor and it does need to clean out from time to time , when the cooler doesn't work -doesn't cool- this is the first thing to look for clean it and see how it goes, it is a normal maintainance to keep the cooler working . God Bless and have a nice day
2coolrick
Cool Blue Services
  • 560 Answers
  • Posted on Mar 14, 2010
SOURCE: where can i get the parts for this wine
try Sears parts direct online first. They carry a wide variety of parts for several makes and models of refrigeration units.
Anonymous
  • Posted on Apr 21, 2010
SOURCE: Everstar Beverage/Wine Cooler HDBC36ID not cooling
Sorry to break it to y'all, but Everstar went out of business (probably bankrupt). There's nothing filing a lawsuit would do now.
Is it worth fixing an everstar wine cooler hdbc361d
Everstar Beverage Wine Cooler HDBC36ID not cooling
Ouch ... prior fixya thread on this model paints a pretty bad reliability picture...
Feb 15, 2018 • Furniture
Stopped cooling
go to your cooling control pannel ,,,, increase its number, set high your freezer temp, if you dont get any benifit, call to a service man . your compressor may be stopped working
2answers
Everstar hdwc35
Do you still have your Franklin HDWC35 wine cooler?
Feb 08, 2014 • Furniture
1helpful
Kenmore wine cooler 13485 spill wine in the top not cooling
if suction line is warm and pressure line hot . sounds like comp is trying to do its job / ck the fans and they may be slow or not going . spilling of the wine did not cause problem . .. but now is the time to correct the problem .. mm / ps if unit is running like you state the you might look at the ref charge . as it may be low . mm . hope this hs helped . feed back pls .. mm
Marvel 61wc wine cooler turns on, but doesn't cool
If you can hear the compressor running and there is no cooling happening your unit has either lost it's refrigerant due to a leak or the compressor is completly worn out (or both). If you just hear the condenser fan running (air blowing), then maybe the compressor just has bad electricals (starting relay, overoad, run capactor) or it has developed a bad winding and will need to be replaced.
If you know you have lost refrigerant the repair will be quite costly and you should consider replacement. If you feel it is a failure of the small electrical parts for the compressor, repair would be more cost effective.
You can get further trouble-shooting assistance and order parts direct from the factory at 800-223-3900.
You can look up a local servicer on their web-site at www.lifeluxurymarvel.com
Should you desire to attempt electrical repair yourself, reply to me and I will provide further troubleshooting assistance or you can contact Marvel Customer Service at the number above. Good-Luck, Subdriver
2answers
Can manuals and parts be ordered for Everstar wine coolers, HDBC36iD is the model. Thanks, Dave
Im sorry franklen indust everstar wine systems are very hard to get parts for also the manual Not a very good unit eather according to reviews
1helpful
2answers
Everstar mpm08cr bb4 will cool briefly then briefly blow hot air
check your filter and replace,, and that dont do it,, you need to clean coils,, and if that dont work it may be low in gas,, hope this help you
80helpful
12answers
I returned our unit to Home Depot with relative ease... I think they were all aware there is a problem with these units.
They refunded the full purchase price (even though I was well past the 12-month warranty period). I put the money toward a GE Profile unit that's a little bigger - more expensive, yes; but it works, priceless!
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
