Here is a tip that I wrote about what I found out about the fabric softener not dispensing into the washer...
Fridgidaire Washing Machine Fabric Softner not going into washer
heatman101
SOURCE: NEPTUNE WASHER
"downy ball" is designed to open at the end of first spin that is the way to go without stopping machine. works very well and costs just a few dollars
SOURCE: Bleach and Fabric Softner Dispenser
This is absolutely normal and you dont have to worry about it..
The reason for this:
The fabric softener compartment uses an over flow method to get the
fabric softener out of its compartment and into the wash load. Water
comes up underneath through a syphon tube and gently fills the fabric
softener dispenser and causes it to over flow in its diluted state. The
reason for this is that it is the most effective way for fabric
softener to be diluted prior to hitting the clothes in the drum. Fabric
softener has to be diluted before coming into contact with fabrics.
This is in contrast to how detergents dispensers work which simply
flush the soap powder in to the drum by water being squirted on to it
from above.
It is perfectly normal to have a fabric softener dispenser full of
clean water after the wash cycle. Just lift and empty it out when you
need to fill it with fabric softner for your next wash
SOURCE: Fabric Softener Won't Dispense
The fabric softener dispenser is notorious for clogging. Liquid fabric softener is essentially a liquid form of wax. After a period of time it begins to gunk up the inside of the fabric softener dispenser. If you remove the dispenser drawer and look into the cavity, there should be a series of holes in the upper part of the compartment where water sprays into all the dispenser trays. These holes get gunked up and clogged and water will not dispense properly. As a result, the washer goes through a complete cycle, but the dispenser stays full. If this is the case, you can take some cotton swabs and/or toothpicks and clean these holes real good. It may be a bit meticulous, but it should take care of the problem. Post back and let me know if this helps.
SOURCE: Fabric Sofner won't dispense
hi there remove the soap drawer then remove the cover over the softener compartment you will more than likely find a blockage in the cover siphon or the down tube on the drawer
SOURCE: Bleach and Fabric Dispenser not working
Got a Brand new LG ~ WT5001CW toploader today. I did 2 loads of wash. Theres a Bleach Dispenser on the top left side but I didn't use it. In the middle of my 2nd wash I noticed the bleach dispenser was full of water. I thought well maybe after the rinse and the spin it would take the water out. Well when the cycle was complete the Bleach Dispenser was still full of water.
I took the Bleach dispenser out and checked the holes to see if anything was plugged, didn't look like it. Was wondering if anyone knew how to solve this problem or do you think that since I took the bleach dispenser out and put it back it that it might work for my next load ??
Any opinions will be greatly appreciated !! Thanks Much !!
