Question about Ruud UBHC Air Conditioner
Ruud gas Furnace UGPH 07EAUER cycles properly heats to temp and shuts down normally.....then a little while later it cycles, but does not ignite. Blower circulates cold air through the house negatiing the heating it has just accomplished. Amber LED flashing rapidly. (I think this is for low flame, I have read that there is a furnace "Cool Down" cycle/mode. It does this even if the thermostat is in the off position. How can I tell if it's a problem at all or normal operation, a problem with the thermostat, or furnace problem??? The furnace seems to work fine except on lower temperatures 64-68 it overshoots the temp as well. I have a mercury switch round thermostat. Not sure where to concertrate my efforts. It is maddending to hear it continue to cycle and do nothing but blow cold air, if I turn the heat up after it stops then it cycles properly, burners ignite etc.
  • Ruud Master
  • 3,336 Answers
Whew...
Most likely... Your part number (look it up)
RUUD 47-25349-?? (LIKE: 02, 03, 07... etc).
(typically: $10 -$20 range... easy job)
On eBay:
A bit slow getting this answer out on the table...
Sorry anonymous.
BUT for the "over-temp" condition...
Forget the wall THERMOSTAT.
There's usually a switch to option the "DEPTH" of
your heating cycle
(Look up Owners GUIDE for your SPECIFIC MODEL).
The "cool down"... (if there is one) would more
likely be you heaters OWN (fan) THERMOSTAT...
It SHOULD not be getting that much RESIDUAL heat
(possible plenum failure... but hopefully just the switch).
Here you have to ask yourself...
Is IT TIME to get your heater
PROFESSIONALLY inspected...
Pacific Gas & Electric used to do that for FREE...
but in this new, improved UTILITY climate
we enjoy today... I doubt they''ll do more than TAKE OUT
a few blocks in SAN BRUNO for FREE anymore...
(you might want to check...
(Same DEDIATED workers w/ really poor Management)).
(My opinion: FAT CAT, CRONY, bought & well-paid
EVIL/corrupt Government "oversight" (CPUC)).
There SHOULD also be a HIGH TEMP
fuel shut off "SAFETY" thermostats..
All these should only be handled with skill & knowledge...
as GAS APPLIANCES can be quite dangerous in the
WRONG HANDS...!!
I am just saying...!!
I'm here daily... Comment me back if unclear.
Happy hunting.
Carnac the Magnificent Y
Posted on May 10, 2017
5 Suggested Answers
Anonymous
SOURCE:
Anonymous
  • 288 Answers
SOURCE: RUUD Heater and Ac MODEL #UGPH-07EAUER
It sounds like the thermostat is not functioning correctly. Has it been changed recently? I think the green wire is connected directly with red somewhere, maybe touching within the wiring in the wall. Also make sure the thermostat is set to auto not on. Sorry if you knew that but you would be surprised how many people don't.
Posted on Mar 05, 2008
Anonymous
  • 340 Answers
SOURCE: blower fan is not coming on
I recommend you getting service its a safety thing. the humming is the transformer and is normal.. good luck Tom
Posted on Jun 23, 2009
Anonymous
  • 614 Answers
SOURCE: My furnace comes on and heates the house for about
Make sure filters are clean . if they are stopped up the unit will over heat. Lets start there. Russ
Posted on Mar 23, 2010
Testimonial: "James, YOU DA MAN!! I would have never guessed the filters could cause these symptoms. Recent carpet cleaning may have added to filter clogs."
Anonymous
  • 18 Answers
There is a limit switch that is likely opening. Be sure your filters are clean and all registers and grilles are open and not obstructed. If the problem continues, you may have a dirty indoor coil or undersized duct work. Some models have a window where you can observe the LED lights. If when the furnace shuts down you see any blinking, you need to count the flashes and we can figure out what the problem is from there.
Posted on May 22, 2010
Gas furnace short cycles 2 minutes or less. Multiple troubleshoot steps and replaced components - no help. Any advice?
I did not see that your indoor fan motor started. Near your indoor fan motor there is a temperature switch that is called the fan delay relay. On a temperature rise the relay shuts a contact that turns on the indoor fan motor. If the contact does not close the high temperature limit will shut the gas controls off like your getting. A fan delay relay also allows the fan to run a minute or so to carry away the remaining heat in the furnace and help cool the furnace down. The fan delay relay is normally mounted in a recessed area in the fire wall of the furnace plate. I have also seen them on the top of the furnace heat exchanger. Anyway, the fan delay relay will probably not be available on a sunday, so temporarily until parts are available, try turning the thermostat fan from auto to on and try the furnace again. By turning on the fan to on the high temp limit will not shut you down again.
I have had high temp limit change there trip points, but you said you bypassed it and did the same thing.
Another cause could be using the wrong type of air filter. The new pleated filters sold block to much air flow. If air mass flow rate drops the difference in temperatur go up and when the difference in temperature go up, it gets nearer the high limit and causes it to trip. All pleated filters drop normal air flow through ducts by at least 35%. To make your air duct system work properly use the what is called throw away filters which cost about 1/3 the cost of the pleated filter. Remember to either clean or change the throw away filter monthly to reduce dirt being drawn into your duct system.
Hope this helps.
Feb 13, 2015 | Heating & Cooling
Ruud 90+ Model UGRA 10EZAJS Trips Out
Check for condensation buildup in the Induction Blower housing. The condensate tubes or canister may be blocked and causing the diaphragm switch to trip the unit out causing the burners to shut down.
Feb 11, 2012 | Ruud Heating & Cooling
May 13, 2010 | Ruud UBHC Air Conditioner
Mar 22, 2010 | Ruud UBHC Air Conditioner
Gas furnace, main burner ignites the other 2 don't. then shutdn.
Between the burners is a small rail in the pressed steel where the flame runs across to light the other burners and it sounds like there is dirt or debris in the step over rails causing the problem. You will need to use some compressed air on those rails to clear them out. Once the rails are clear the other two burners should ignite right away.
Dec 21, 2009 | Heating & Cooling
Blower fan is not coming on
Jun 22, 2009 | Ruud UBHC Air Conditioner
Furnace not cycling properly
sounds like the flame sensor needs to be replace. You can try cleaning it with steel wool. This will get you by for a little while.
Jan 17, 2009 | Honeywell Electronic Programmable...
RUUD (Protech Model 500) Thermostat Single Stage Not Programable
problem is not the thermostat, thermostat is an on-off switch that happens to work on temperature. Your furnace is locking out. cycling the heat off switch resets the micro-processor in the furnace. You need to diagnose the problem in the furnace, to go further we will need the model and approximate age of the unit
Dec 11, 2008 | Ruud UBHC Air Conditioner
Ruud UBHC Air Conditioner Logo
347 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Dennis Boxerman
John Tripp
John Tripp
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
