Mtd 22" Yard Machine Push Mower Logo
Posted on Dec 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have a 22 inch yard machine snow blower the belt that turns the blades broke what size belt does it take
Anonymous
Level 2:
Scholar:
  • Expert 127 Answers
  • Posted on Dec 27, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
127
Questions
0
Helped
181286
Points
364
MTD has made many 22" machines over the years. Please repost your question indicating the model #
1helpful
Yard machine 8hp snow blower blades turn slow how can i fix it
on some blowers there is an idler pulley that is adjustable. take the guard off and look to see if there is a way to adjust the tension on the belt to make it tighter if not a new belt may be needed.
Jan 15, 2019 • Garden
2answers
What is the auger belt size for craftsman snowblower model C950-52151-1?
https://www.google.com/search?q=C950-52151-1&rlz=1C1CHBF_enUS757US757&oq=C950-52151-1&aqs=chrome..69i57.655j0j4&sourceid=chrome&ie=UTF-8
Auger blades are spinning
sound like you might have 2 problems. If auger doesn't engage in heavy snow you probably just have ice accumulation inside the impeller. Dont try to engage until impeller is cleared of snow (shut off and unplug spark plug before cleaning) Second if blades are spinning than you must have hit something in your path and broke the shear bolt (about 2 bucks at hardware shop) remove the old bolt and replace it and it should work again if this is the problem. Good luck.
Snowblower augers wont turn
Did you check shear pins on shaft for auger
1helpful
I have a snow blower which will start up but it won't move forward in the snow nor will it push the snow. Not sure what is wrong. I can manually move the blade around that pushes the snow.
If you start the machine and the axles spin but the augers do not it is because the shear pins are broke. If you look closely you will see the the augers have shear bolts and nuts or shear pins. If you jam a piece of ice or a stick in the augers while they are spinning the bolts will shear so you do not damage the expensive augers or the worm drive gears. If the axle spins with the augers you may have torn up the front worm gear in the front of the auger intake. If you spin the small auger and the large auger moves but when you start and engage the auger nothing happens you will have to remove the under cover and inspect the drive belt pulleys for jammed or broken parts or more commonly broken drive belts.
I have a yard machine 5hp 22" snow blower. The
TRY PUTTING SOME SEA FOAM IN YOUR GAS AND LET IT RUN AWHILE MAY HELP.
On my two stage snow blower--main auger stops turning .
Hi, I figured out the problem. The gear transfer case between the augers must be broke. The auger spins slowly until it hits snow and then stops-- The discharge fan continues to spin fast. I will try to get a local handyman to fix it or else but a new machine, this one must be at least 15-16 years old.
I thank you for your help, it is a great service. ojohn
Dec 10, 2008 • Garden
Top Mtd Garden Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
john h
Are you a Mtd Garden Expert? Answer questions, earn points and help others
