The motor is easy, just pull off the plastic hubcap with a flat head screwdriver, then remove the nut and bolt with a 13mm wrench, then pull off the wheel and gearbox and disconnect the wires from the motor then its just two screws that hold the motor on, for the circuit board it depends on wether you got the new style with the poly switches on the board or if they are seperate
SOURCE: do I need to replace all tires on peg perego john deere
Hi!
On these, only the 2 rear wheels are the gear wheels. You will just need to replace the tires on those with the rubber ones if you choose to go that way.
SOURCE: wiring specs for peg perego polaris 700
I would contact the repair help at
http://www.shopjandl.com/
They seem to know a lot about these toys
SOURCE: The Peg Perego Polaris Sportsman 700: 4 wheel sit on bike
Just go here they have everything plus free diagrams and manuals.
http://tigerimports.net/sunshop/
Hey, I found the manual here: http://us.pegperego.com/admin/archive/manuals/polaris%20800_FIUS0802G120_IGOD0510.pdf.
If you're talking about the low and high speed settings, it says there is a screw on the side of the pedal, it's on page 5 steps 51 and 52.
There have been shut off problems with this device that the customer service suggests is due to the battery. From what I read there are no override switches for this. I hope this helps.
