If your battery is in good condition (check this one first, take it to your nearest autozone they'd do it for free) then you need to replace the voltage regulator, this one is located on the back of the unit under the back cover of the main engine, it looks like a black rectangle with two cables. For teh second problem, check your fine voltage button and increase it as needed until the rod does not stick to the metal, but not higher enough to pierce or burn thru it.
