You need to replace the ptc overload relay replaced on the compressor as this component is getting weak and is cutting out,it uses temperature vs. heat to protect the compressor from a no start or when the compressor cant operate on the run windings and overheats,then this ptc overload relay cuts out the compressor to protect it,it will keep trying to start the compressor till the ptc burns out,it just unplugs off the compressor and a new replacement plugs back in
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
heatman101
