Hello, welcome to FixYa.
The Key symbol means the lock has been activated some how.
On most bosch of your class this is how you work it on & off.
Here`s how to deactivate it...
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly.
Thank you for visiting "fixya" for your washer solution inquiry.
good luck going forward.
macmarkus :)
Press and hold START/PAUSE button for 5 seconds and the child lock should release off.
You could have accidentally activated the child lock. If this wont work, then remove plug for few minutes then press start/pause holding it for 5 seconds to release.
My front loader washing machine(BOSCH AXXIS+) HAS THE CHILD LOCK ON.... CANT OPEN IT! TRYED UNPLUGGING IT BUT DOESNT SEEM TO WORK.. HERLP ME PLEASE!!!!!!!!!
How could I set off the children lock?
I have a key ikon on the display, and the machine doesn't start any program.:)
