Question about Bowflex Selecttech 1090 Dumbbells
My bowflex dumbells are jammed and i cant remove them from the holder
    New Friend:
Hi I called 1-800-628-8458 (the number in the manual) after trying several of the methods shown here. None worked. your dumbbell needs to be on a flat surface, no roll the dumbbell over to where the weight is facing the floor and the base is up in the air. With both hands lift the base and gently shake, the weight should fall out. Put the base back on the floor face up and inspect the grooves where the weight plates go for any debris. Clean this area if you find debris. Now you will need a pen or pencil with your weight. Grab your weight, still facing down and you will see a black release button on both sides on the inside of the weight. It is in between the metal dial and the inner part of the weight. Now press down on that button with your pen or pencil and start turning the dial (caution: the weight plates are going to fall out) keep turning until all of the plates are out. Do the same thing for the other side. Now grab each plate and put it back on the base where it goes, the smallest plate on the outside to the largest plate on the inside, make sure the small metal piece on the bottom of each plate is facing away from the inside of the base. Do this for all of the plates. Now back to the dumbbell. Grab your pen or pencil again and press down on the black release button and turn the dial to where the number 5 or lowest weight is selected where it reads Bowflex. Do this for both sides. Now grab your dumbbell and carefully put it back into the base. It is important that you put the dumbbell down straight, avoiding any shifting in plates.
I hope this helped.
Posted on Mar 18, 2014
  • 1 more comment
  • Jay Cabral
    Jay Cabral Jul 28, 2016
    Thanks! Save my life!!!!
  • Anonymous Oct 31, 2018
    Thanks, this solved the issue for me!
  • Rick
    Rick Nov 08, 2019
    Worked perfectly for me. Thanks
2 Suggested Answers
6ya staff
SOURCE:
John Peattie
SOURCE: One of my Bowflex Dumbell's dial will not turn,
Hi there, I wanted to add my solution to these as I bought a set of second hand bowflex dumbbells only to find one of them wouldn't turn. The dail kept sticking or just not turning. After hitting goggle and coming up blank i turned to the tool box lol I set the bar to 5lb both sides and removed the handle, leaving all the weights in the base, I then removed the weights from the base one by one. Once the base was empty I replaced the empty handle onto the empty base and tried to turn the knob, it wouldnt turn, on the base there are two metal hooks, these stop you pulling the handles out In between weight settings, the metal hook on the base was hitting the metal disk (which has many hooks all around it) on the handle. I lifted the handle off Swaped sides and it still was hitting the metal base hook. If you undo the 6 screws on the underside of the base and pull apart the two halfs you will find a large black square which is held in place by 2 more screws, remove these and pull out this square, you will now have access to the underside of those two metal hook (which are held in place by two screws each) undo these a little and push back on the hooks and retighten these screws, turn the base over and replace the handle to see if the dial will turn freely on the base. Replace all the screws, re fix the two base halfs together, sit the weights down in the base, place the handle back and turn that dail Hope this helps someone.
Posted on Feb 11, 2012
Printer head going one side and given beep
IF the jammed paper tears and you cannot remove the paper either from the paper output slot or from the transport unit, or the jammed paper remains inside the machine, remove the paper following the procedure below. 1. Turn off the machine, and unplug the power cord of the machine from the power supply. 2. Open the paper output cover. Remove the paper on the front tray if any.
Important:
    Do not touch the clear film (A). If the paper or your hands touch these parts and blot or scratch them, the machine can be damaged.
3. Make sure that the FINE cartridge holder does not hang over the paper. If the FINE cartridge holder hangs over the paper, move the FINE cartridge holder to the right edge or the left edge whichever is easier to remove the paper. When you move the FINE cartridge holder, hold the FINE cartridge holder and slide it slowly to the right edge or the left edge.
4. Hold the jammed paper with your hands.
If the edge of paper is jammed near the paper output slot, pull the edge of paper to the position where you can hold it with your hands.
5. Pull the paper slowly not to tear it, then pull the paper out.
6. Make sure that all the jammed paper is removed. If the paper is torn, a piece of paper may remain inside the machine. Check the following and remove the piece of paper if it remains.
7. Close the paper output cover, then reload the paper.
All print jobs in the queue are canceled. Reprint if necessary.
Jul 21, 2014 | Epson LX-300+ II Matrix Printer
How do i clear paper jam after tearing half of the paper leaving other piece locked inside machine?
Important:
Jul 20, 2014 | Canon Pixma Mx432 Wireless Inkjet Office...
Bowflex TC5500 fuse for motor board. When staring the machine for work out, the motor kicks off then reboots. How do we order and replace a fuse?
You can order the part:www.fitnessrepairparts.com
or www.gymparts.com
www.treadmillpartszone.com
You must locate to side from the power switch you must find the fuse holder and replace the fuse with THE SAME SIZE+CAPACITY+VOLTAGE INDICATED FROM THE SAME FUSE.
Remember if the fuse is Blown again or continuing you have a short circuite in a) Transformer b) Main Motor c) Main Controller Board d) Faulty ground in your receptacel from the wall very carefully.
11_28_2011_7_10_12_pm.gifattached the block diagram that I did for to illustrate to person like you, good luck. sincerely.
Oct 03, 2011 | Bowflex Treadclimber
Once the dumbell is on the base the dial will not spin so you can not pick up any weights. I can push the putton on the bottom when I am holding the unit with out any wieghts and the dial will spin but...
Try setting the handle in the plates back onto the carrier(bottom). Lightly tap on each plate that is stuck. Now push the plates down (vertically) onto the bottom carrier. Now try turning the dial (side that was stuck). It worked for me. Have my 1090 plates were stuck on the handle. Good luck
Jun 11, 2011 | Bowflex Selecttech Dumbbells
I need a weight from the select tech dumbells as one of them has broken where can i get this from
Here are parts lists for the SelectTech 552 Version 1 and the SelectTech 552 Version 2. Looks like some weights are not available but some of them are, depending on which version is yours I hope the one you need is available.
May 04, 2011 | Bowflex SelectTech 552 Dumbbell Pair ...
Selecttech 1090 Dumbbells: the end caps that adjust the weight are stfrozen, ...
Just call Bowflex. If you don't want to call here's the solution. There is a reset button on the bottom of the handle. Take the handle out, place on the floor side ways, depress the square button and turn to 5 lbs. Whatever weights that were on handle will fall out. Place the weights back into the holder. Make sure they are positioned correctly then put the handle back. Then test by dialing up different weight settings and lifting the ******** out of the holder. You should be back in business. If that doesn't work call Bowflex which you should do anyway.
May 18, 2010 | Bowflex Selecttech 1090 Dumbbells
Apr 01, 2010 | Bowflex Selecttech Dumbbells
The selecttech dumbell adjuster will not move. It says there is 7.5 lbs on the bar and there is actally only 2.5 lbs. The adjuster wheel will not turn. How do you fix it?
Push the button on the bottom of that releases the adjuster to spin. Set both to sides to 5, put all the weights back and your ready to place it back and select a weight.
Jan 21, 2010 | Bowflex Selecttech Dumbbells
Bowflex Selecttech 1090 Dumbbells Logo
12,811 people viewed this question
Top Bowflex Sport & Outdoor - Others Experts
Jerry Greenberg
Jerry Greenberg
Paul Carew
ray gallant
Are you a Bowflex Sport and Outdoor - Other Expert? Answer questions, earn points and help others
