Hello Here are the bios beep codes: 1 long, 2 short Repeating (endless loop) 1long, 3short High frequency beeeps while running Check computer beeps and act according to suggestion Hope it helps if so do rate the solution
Video adapter error
Either video adapter is bad or is not seated properly. Also, check to ensure the monitor cable is connected properly.
Memory error
Check for improperly seated or missing memory.
No video card or bad video RAM
Reseat or replace the video card.
Overheated CPU
Check the CPU fan for proper operation. Check the case for proper air flow.
Repeating High/Low
CPU
Either the CPU is not seated properly or the CPU is damaged. May also be due to excess heat. Check the CPU fan or BIOS settings for proper fan speed.
