Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Had the same problem with the RCA HD52W20 that was blinking 3 times when you try to turn it on, i already replaced the 3 capacitors CP150, CP114, CP120, but when you turn it on it does turn on but the image is blinking it has good sound and good picture colors but the only issue now is that the image is blinking all the time and at every blink on the screen you can hear a click noise on the boar the click noise on the boar is not loud you can bearly hear it, please help me i dont know what else to replace and i raly love this tv sound and picture, thanks in advance.
6ya staff
SOURCE:
ladywinn
ladywinn
  • 5138 Answers
SOURCE: Replaced the Capacitors, Still have a Power Issue
Resolder all the pinns on Flyback transfomer.
Posted on Feb 13, 2009
ABRsvcs
  • 4234 Answers
SOURCE: Rca d52w19 push power flashes 3 times
The caps in these sets rarely bulge. Try checking the Horizontal Output Transistor (HOT). I suspect that it is shorted. The noise you are hearing is the power supply attempting to fire. With the defect further on, the power supply will turn itself off as a safety valve.
Keep us posted,
Dan
Posted on Feb 21, 2009
Chi Chu
  • 8457 Answers
SOURCE: Where are these caps?
DM power board.
Posted on Jan 21, 2010
Willie Howell
  • 1030 Answers
SOURCE: what circuit board would i
this is located on the power deflection board... toward the front around a heat sink
Posted on Oct 20, 2010
Testimonial: "awesome....thank you"
Jack Olszewski
  • 12 Answers
SOURCE: I have a RCA D52W20 52" HDTV Ready TV which I
Unplug High voltage lead from HV splitter. This is a red wire going from HV transformer to similar (white plastic) device located up front, between picture tubes. Disconnect the one which is coming in, by strong energetic pull down with pliers. Leave those which go to picture tubs in. Make sure that disconnected wire is far from other components or metal parts (high voltage - SEVERAL INCHES SPARK CAN OCCUR) Turn the unit on - if different than 3 blinks - the splitter is your problem.
Posted on Feb 13, 2011
Power button is pushed blinks 3 times then nothing
sounds like the cP150, CP120 and CP114 capacitors need replacement. You can get the CP150, CP120 and CP114 repair kit from www.tvrepairworld.com the kit contains the capacitors and the CD with instructions.
Mar 02, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
When we turn the tv on in blinks the green light 3 times and never turns on. what is wrong with it?
Feb 26, 2011 | RCA R52WH73 Projection Television
Rca d52w19byx1 when i turn on, the light blink 3 times then dead
Capacitors cp120 cp114 cp150 look to see if they are swollen vented or puffed up on top.220uf 35v and 1000uf 16v use 25v.
Jun 01, 2010 | Televison & Video
I turn my 50" rca on and the power light goes on and blinks with no sound and no picture the powers down ... help please
Look for a pattern in the Blinks then check for an error code in your user manual. It will tell you what has failed.
Dec 29, 2009 | RCA D52W19 52" Rear Projection Television
52"rca hdtv lights blink will not turn on
Thats the classic sign of the CP150, CP120 and CP114 capacitors having failed. By trying to power it up over and over the caps will eventually charge and the set will function untill you power it down. You can get the CP150, CP120 and the CP114 repair kit at www.tvrepairworld.com and the kit contains the CD with repair instructions.
Dec 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA d52w25 52 inch blinks 3 times off...turns on...off
Most likely Capacitors cp150, CP120 and CP114 need replacement. You can get the repair kit at www.tvrepairworld.com under the RCA reapair kits catagory bottom of the page. The kit contains the capacitors and detailed instructions
Sep 09, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Can't turn on tv
Check capacitors cp150 2200uf 16v and cp114,cp120 220uf 35v- If cp150 is puffed up on top replace all 3 capacitors.
Jan 13, 2009 | RCA D61W20 61" Rear Projection Television
RCA 52 in tv
ON Deflection board there is 3 capacitors that most of the time will cause set not to startup cp150-cp114-cp120. values 2200uf 16v, two 220uf 35v, you buy caps at Radio Shack.
Dec 28, 2008 | RCA D52W19 52" Rear Projection Television
Come on and goes off
3 bad capacitors located in front of deflection board cp150 cp111 cp114 they are green with gold writing on them if cp150 is bubbled up on top it is bad. 2200uf 16v. so replace all 3 capacitors.
Nov 22, 2008 | RCA HD52W59 HDTV Projection Television
Tv will not turn on
Look on Deflection board 3 capacitors need replacing cp150---cp114----cp120 one is 2200uf 16v Two of them are 220uf 35v. Buy capacitors at Radio SHack. If cp150 is puffed up on top it is bad so replace other 2 caps as well.
Dec 18, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
140 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
