Nintendo Wii Console Logo
Posted on Dec 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My wii remotes just stopped working, fresh batteries, unhooked everything.All lights flash.
Anonymous
Level 3:
  • Master 839 Answers
  • Posted on Dec 15, 2010
Anonymous
Master
Level 3:
Answers
839
Questions
0
Helped
103418
Points
2293
This is a minor problem so better dont take it repair shop you can do it by yourself
I want to just make it clear to you, that you can repair the following problems at home with a good repair guide. There is no technical knowledge needed you simply do what you see on the step by step videos or the paper guide.
click here to download repair guide
How do you connect a rock candy remote to Wii
Make sure you have fresh batteries in it. the little red button under the battery cover is the sync button. Push it and you should see the 4 blue lights flash on the remote. Push the sync button on the Wii (red button under the front flap) and wait a few seconds. The remote light should stop flashing and one of the lights should light, indicating which remote it is (1-4) Repeat as necessary or change the order of button pushing if it doesn't work the second time.
Wii remote wont connect ?
if it wont sync after using the red buttons then its just bad batteries from the sound of it or the remote has gone bad.
Try fresh batteries or let the rechargeables charge (assuming they arent bad)
The Wii Remote for the second player does not work. Once in awhile the blue lights flash. We have tried to follow the instructions for synchonizing the remote with the console. And we have put in fresh...
Our grandson emailed the solution.
Turn on the Wii and open the game menu.
Click on the Home button.
Click on the Wii remote settings at the bottom of the screen.
Press "Reconnect" and then hold 1 and 2 on both remotes.
We will have to follow these steps every time we want to use the Wii.
It seems like a 'bother', but it works. At least so far.
1helpful
2answers
Remote does'nt work 0n my WII
you have to sync the remote with the wii, there is a small button inside the door on the front of the wii
1helpful
My wii remotes wont pick up signal blue lights flash then just go back out again
Hi, check the batter level and then try re-synching the remote's.
Here's instructions for both:
f4bc8924da.gif A fresh set of alkaline batteries should last, depending on amount and type of use, up to 35 hours. This can vary greatly based on certain factors, such as Wii Remote Speaker Volume, Rumble, battery quality and age, and type of game being played.
Important Note: If you are using rechargeable batteries, the only type of battery recommended are Nickel Metal Hydride batteries. When it comes to using rechargeable batteries, you must follow manufacturer guidelines for safety and proper usage. Failure to do so could cause damage to the Wii Remote and void the warranty.
There are two ways to check the Wii Remote's battery levels:
  • Remove the battery cover and press the Red "Sync" button. The number of lights flashing indicates the Wii Remote's battery strength. Four flashing lights indicates full strength, with one light flashing indicating the lowest level.
    or
  • Use the HOME Menu to check battery level of each Wii Remote:
    1. Press the HOME Button on a Wii Remote that is synchronized with the Wii console.
    2. Select the Wii Remote Settings option from the Home Menu.
    3. The battery level of all synced Wii Remotes is displayed along the bottom. Four bars indicates a full charge, with one being the lowest charge.
55851daefd.gif Note: Make sure you have placed batteries in the Wii Remote.
  1. Press the Power button on the Wii console to turn it on.
  2. Remove the battery cover on the back of the Wii Remote you wish to sync up, and press the SYNC button just below the batteries. The Player LED will blink.
  3. Open the SD Card Slot cover on the front of the Wii console and press the SYNC button on the inside of the compartment.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 to 4).
This procedure must be followed for each additional Wii Remote added to your system.
I hope this helps
Mike
Wii remote will not turn on and the blue lights either
all you have to do is open the place where you put an sd card on your wii then open the battery cover on the wii remote and press the SYNC buttons at the same time and it WILL TURN ON trust me it works
1helpful
Wii Remote A/ B problem
I know this sounds silly, but be sure that you have fresh batteries in each Wiimote and that you have them in the right way.
Whenever you start up your Wii, the first Wiimote that you press a button on becomes controller number 1 and then subsequent Wiimotes are added in the order a button is pushed on them. SO, if you are thinking that you have remote 1 because that was the one that was remote 1 last night, it doesn't necessarily mean that it is so. Be sure that whenever you activate a Wiimote, the lights flash - 4 lights flashing mean strong battery, 1 light flashing means replace; when flashing stops, the number LED that is lit from the left denotes which remote you have. Make sure that is the same Wiimote that you select a game with, and make sure that is the one you press A&B together with to start the game.
If it doesn't work, shut everything down and start up using the other Wiimote. If that DOES work, then it could mean that your other Wiimote is not syncronized with the console. See the directions in your Wii manual on syncronizing additional Wiimotes (they're called Wii Remote by Nintendo) to your console.
Good luck. If all the above fails, you may want to go to www.nintendo.com and request customer service.
5helpful
3answers
Canot use Wii fit balance board
Ensure batteries are fresh. Ensure that Wii Fit (or other Balance Board game) is started up completely before pressing the power button.
2helpful
2answers
WII REMOTE WILL NOT CONNECT TO THE CONSOLE
Make sure the batteries are fresh, and then open the battery compartment. There is a little red button. On the front of the Wii (turn it on), open the door where the SD memory card goes in. There is another red button. Press them both at the same time. The blue lights will flash on the remote, and it should then work.
Repeat for each controller.
394helpful
48answers
Wii Remote Control Stopped Working
This happened to my son. I did some reading and found out you have to resynchronize the remote. This is from the manual
1) Press the Power button on the Wii console to turn it on.
2)Remove th battery cover on the back of the remote and press the SYNC. button inside the cover. The Player LEDs will blink.
3)Open the SD Card Slot cover on the front of the Wii console and press the SYNC button on the inside of the compartment
4)When the Player LED blinking stops,connection is complete. The LED that is illuminated indicates the player number.
This procedure must be followed for each additional Wii remote added to your system.
This worked for me, hope it helps you.
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
