Eljer Toilet Seat  Tosca  124200000 Logo
Posted on Dec 14, 2010
I need a Toska toilet seat replacement - Eljer Toilet Seat Tosca 124200000
  • bbuzz56 Jul 02, 2011
    Thank you
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on May 23, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1004
Points
Allen in NY has Eljer tosca, savannah, patrician & others.
his # is 914-403-8300
A
Anonymous
Toska seat is called Manarque seat, for the Herbeau toilet.
I searched for square toilet seat.
Site shows toilet seat for the Herbeau $135
http://www.bizrate.com/miscellaneous/herbeau-toilet-and-toilet-seat/
http://www.faucetdirect.com/herbeau-0651-monarque-elongated-toilet-seat-with-cover-and-finish-matched-hardware/p671327?source=shz_671327&aid=228165868
Pdf from Eljer showing Tosca toilet looks very similar to product shown on links above.
1.6 gallon water-saving flush tank.
http://dallas.eljer.com/Products/Toilet/CatalogPage/0912000.pdf
Where is the serial number - toilet is 25 yrs old and need a new toilet seat.
Typically there is no serial number associated with a toilet seat. The seat will either be a round front or an elongated seat. Just make sure the shape is the same when purchasing the replacement seat.
How to replace a toilet seat
There are round and oval seats.... take note of which you need. Back towards the bowls water tank on the toilet seat you will notice two tabs....pop open with a screwdriver. You will see the screws holding the toilet seat in place. .
Reach under the screw there will be a plastic nut. Hold if while you losen the screws with the Screwdriver....remove and replace seat. ... install screws and plastic nuts again.... and your finished. ...5 minute repair
Sep 30, 2014 • Home
2answers
I need a toilet seat replacement of Porcher Veneto Toilet. The part number is 70030-00-001 and I'm told by Porcher is no longer available. They say no other seat fits. Any ideas? Where to find
I had the same issue and basically called every single american standard distributor I could find. I finally found one! They had the gold hinges but I didnt care, it fits and works fine. Make sure you know the part number. I had a good salesperson that knew to look for any color hinge so I had a seat
2helpful
Replacement seat....size???
American Standard is the brand, so you've got a start there, but 1.6 is a flush measurement. Look around the inside for a tank for a model number - with AmStan toilets it's usually a four digit number beginning with a 2 or a 4. This will be what you need to get the OEM toilet seat. However, since toilet seats are purely cosmetic (they don't affect the functioning of the toilet), you can literally take a few measurements and find something that simply keeps you off the porcelain. http://www.plumbingsupply.com is a good one for toilet seats, btw.
Aug 21, 2012 • Home
Need to replace toilet seat and cover for a Williamsburg, white toilet. The part number I have is 5395.700.....but I have learned this number no longer exists. What number toilet seat/cover fits a...
Your toilet is still offered by the manufacturer:
http://www.americanstandard-us.com/toilets/williamsburg-one-piece-elongated-toilet/
Available replacement toilet seats from American Standard can be seen and ordered here:
http://www.americanstandard-us.com/repair-parts/toilet-seats/
You might consider finding you nearest dealer or choose another on-line retailer:
http://www.americanstandard-us.com/dealerLocator.aspx
Before ordering suggest you confirm with American Standard Customer Service the appropriate replacement seat for your model.
http://www.americanstandard-us.com/customerservice/onlineStoreSupport.aspx
Toilet seat cracked need replacement and aprrox. cost
Hello. A new seat is available at any hardware store. Elongated seats cost anywhere from 20-40. If you need to have it installed it will be significantly more. House calls are generally at least $50.00. Be sure to get a price up front as it only takes 5 minutes to replace a toilet seat.
If you want to do it yourself, unscrew the old one and screw on the new. That's it. Joe
Thanks for choosing Fixya!
NEED TO REPLACE THE SEAT AND COVER OF THE TOSCA TOILET
http://www.homeclick.com/web/catalog/product_detail.aspx?pid=365570&chnl=cse&ven=googlebase&cat=Bathroom%3AToilet%20Seats&brnd=Herbeau&itm=0651'Herbeau%200651%20Monarque%20Toilet%20Seat%20and%20Cover%20Only%20in%20Plain%20White%20-%200651
The picture shown with your post shows a toilet seat that looks like the one sold at site above.
But the site above is selling the toilet seat called the Monarque toilet seat and cover.
The particular seat shown is not called a Tosca.
Another site shows the identical whole toilet, and calls it the Herbeau
The pdf from Eljer showing the Tosca toilet looks very similar to both the products shown on the two links above. Maybe this solves the question.
Can you just buy a toliet seat base??
Im not sure I understand the question so please excuse me. You can buy a toilet seat, and they usually attach to the toilet bowl. If the porceline that the seat is attached to is broken then the bowl will most likely need to be replaced. Most of the time you can replace the toilet cheaper than just replacing the bowl. Hope this helps.
May 09, 2010 • Home
Can't find the right toilet seat from standard stores
Grohe does not make toilets. look inside the tank for manufacturer and model number it sounds like a one piece toilet and the seat bolt nuts are in the tank feel around for them.Grohe only makes handles for toilets to match their faucet finishes
Top Eljer Home Experts
john h
Gene Lawson
Sean Wright
Sean Wright
Are you an Eljer Home Expert? Answer questions, earn points and help others
