SOURCE: How to remove motor shaft sleeve from KitchenAid
I just did this. I used a screwdriver and some needle-nose pliers to wedge and separate the shaft from the base. Once you've separated it by about 1/2 inch, it will come off easily. I simply used a mallet to install the new one.
SOURCE: attachment stuck on shaft of food processor
put the mixing bowl up as much as possible. spray some wd40 into the groove between the attachement and the motor shaft. Wait for several minutes, then with a hammer and a piece of wood, give the bowl a good wack. With a few goes, it will gradually come off. I will be putting some butter inside the attachement from now on to keep it lubricated
