SOURCE: f06 error code on Whirlpool duet washer
An explanation of your error code can be found at the following link:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
In a nut shell, usually one of the motor windings fails, causing the Drive Motor to not rotate at the correct rpm, or not at all. Or, the Motor Control Unit fails. Both are simple repairs and can be accomplished by the average do-it-yourselfer. If you wish to attempt this repair, let me know and I can give you the steps required to complete it.
These parts can be found at searspartsdirect.com. Just type in your model number and look under the "Pump and Motor Parts" heading on the next page. The MCU will be listed as item number 1 (part #8181693). The Drive Motor is listed as item number 16 (part #8182793). You can also try repairclinic.com, pcappliancerepair.com, and partsstore.com for comparative pricing. If you require further assistance, please let me know.
SOURCE: Hotpoint Aquarius WT740 Fault Code
Hi. F05 means pressure switch jammed on full.
Check pump for blockage and that it is working, if no joy you will have to call an engineer
SOURCE: whirlpool awo3561 fault showing as f06? what does
"F06" is a Motor Speed error code. It means the motor is not spinning, or you have a loss of commuincations between the Motor Control Unit (MCU), Central Control Unit (CCU) or Drive Motor. The following link explains:
The easiest place to start would be to verify all your connections between the Drive Motor and MCU are intact and not corroded. Then, perform resistance checks on the Drive Motor windings.
For ease of troubleshooting, UNPLUG the washer and remove the top panel by removing the three screws that hold it in place in the rear of the washer. With the screws removed, the panel will slide back, then off. Position the washer where you have full access to the rear. Remove the back panel of washer. With the top and back removed you will have full access to the CCU, MCU and Drive Motor.
If you have questions along the way, or if you require addtional assistance, please let me know. I hope you find this information helpful.
SOURCE: Hotpoint WD860 - Fault Code F-07
F07 indicates heater relay stuck.
You need to check the heater to see if it is faulty, and fit new one if it is.
Please rate my solution.
Thanks.
SOURCE: hotpoint ultima washing machine is showing a fault
F 05 normally means there is a blockage or a fault with the pressure sensor. The common place for blockage is in the black pipe from the drum to the pump as it has a filter in here and clogs up. remove the pipe and clean the filter out and remove gunk from the pressure sensor on the side of the pipe as well. If that does not fix things the pressure switch could be faulty itself
