Cisco 7940 IP Phone Logo
Posted on Dec 13, 2010
Hi, can someone can enlighten me about CISCO 7940 stuck in Configuring IP. thanks.
Anonymous
Level 1:
  • Contributor 21 Answers
  • Posted on Dec 25, 2010
Anonymous
Contributor
Level 1:
Answers
21
Questions
0
Helped
6062
Points
38
What are you trying to connect this to? cme
  • Anonymous Jan 06, 2011
    the reason for this would be that it is not getting it's config from the CallManager (or CME router).
    The steps in a phone booting up something like this:
    1) DHCP for IP Address, and Option 150 for TFTP Server
    2) TFTP to address provided by DHCP Option 150
    3) Get config file, a(an upgrade of firmware may occur at this point)
    4) Connect to Call Manager/CME as specified in config file
    First check DHCP server to see if it is allocating an address to the MAC address of the phone
    Second confirm if DHCP is providing Option 150 and that is the IP Address of the TFTP Server (typically one of your Call Managers)
    Third check that the phone is correctly configured on CCM/CME. A common error at this stage is that the phone is configured with the wrong model type.
    Cheers, Simmo99.
My Cisco IP 7960 Phone is stuck at "configuring IP"! What is happening? I need to get it fix asap :(
it would appear your phone is not getting an address from your DHCP server, i would start by plugging in a laptop to see if that gets an ip address
Hope this helps
Hi,i wanna use cisco ip phone 7940 as sip ip phone.when i power up the phone ,it can get ip from network,but finally,it shows "TFTP timeout"in display led.All the buttons can not be used.What...
the DHCP server should be providing the address of the TFTP Server as DHCP Option 150. The most likely problems are:
Option 150 not defined, or not the correct IP address of the TFTP Server.
Or possibly your TFTP Server is not functioning properly.
If you have not Option 150 defined, the phone will use the default gateway as the TFTP server address.
Cheers, Simmo99.
How can I clear / reset a Cisco IP Phone 7910
How to set a Cisco IP phone to factory default Reset configuration of Cisco IP Phone (7910, 1911, 7940, 7941, 7960, 7961)
To set the Cisco IP phone to factory default completes the following steps: should be completed:
For 7940, 7941, 7960, 7961 phones:
1. Power up the phone (unplug power cable and plug in again and hold the # key.
2. Release # when lights start flashing.
3. Press 123456789*0#.
4. Press 1 to keep network configuration or 2 to lose the network configuration.
For 7906G and 7911G phones:
2. Release # when MWI starts flashing.
3. Press 3491672850*#.
2answers
Cisco IP Phone 7940 and 3com nbx as 3rd party SIP phones
Here are the instructions for configuring these units for 3cx
http://www.3cx.com/sip-phones/cisco-7940.html
http://www.3cx.com/sip-phones/polycom-soundpoint.html
Since the 3cx softphone worked well, I don't see why you couldn't configure each as for 3cx and make them work as well.
2answers
My Cisco ip Phone 7940 will not ring.
Give me your number, and i'll call you! Solved! =-D
2answers
Cisco 7940 call conferencing
No most system are maxed on the phone ... but if you had a panasonic system they are know for multi conferencing.
My client has Cisco 7940 IP phones and wants assistance with feature programming
This phone can be access through a menu/ setting buttons.
Useful link on how to navigate through the phone:
http://www.cisco.com/warp/public/779/largeent/avvid/products/7940/7940_topic3.htm
I think the main problem is to determine the intergrated router or Call manager configuration
You can also connect on switch and type:show cpd neighbor This will show the physical port connections
1helpful
3answers
Phone stuck in Configuring IP
Did you check the TFTP settings on the IP phone? You may need to disable DHCP on the phone and assign the TFTP manualy or make sure the correct TFTP server is assigned.
Top Cisco Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
