After setting up receiver, receiver turned on but had a amp err messge displayed yet it worked. Once I turned it off again and tried to turn it on the receiver message was amp err and then it turned off with the standby/on switch flash. I unplugged the reciever to maybe reset the receiver however still flashing. By the way when I was setting up the receiver off the televeision, once it was set up to my settings I unplugged the TV connection from the receiver; also since the receiver is in a tight spot I may have pulled on something but I was very careful.
Bluetooth 4.1 Receiver Wireless Multipoint Connection Audio Music Adapter with 3.5mm AUX Port and Hands Free Calling for Home Audio Music Streaming Sound Amazon com Charm sonic Portable Bluetooth 4 1 Receiver Wireless Multipoint...
Try checking your speaker cables as one of them may be touching the case of the amp,or touching another cable,this can cause a short and cause the error message.The amp is protecting itself .
hope this helps.
CABLE GUY.
To do the reset you need to turn the receiver on, then on the front panel of the receiver press and hold the "VCR/DVR" button while doing that press the "STANDBY/ON" button. You will see the word "Clear" in the display screen and the receiver will go into standby mode. PLEASE UNDERSTAND THAT YOU WILL LOSE ALL YOUR AUDIO & VIDEO ASSIGNMENTS ON THE RECEIVER PLUS YOU WILL LOSE ALL YOUR SPEAKER CONFIGURATIONS, SPEAKER DISTANCE AND ALL LEVEL CALIBRATION SETTINGS. YOU WILL ALSO LOSE ANY PROGRAMMED RADIO STATIONS IN MEMORY. Once the receiver goes into standby mode turn it back on and go thru the setup menu for all custom settings.
If you need further assistance please email me at [email protected], Thanks,JT
Resetting the main unit
Use this procedure to reset all the receiver's settings to the factory default. Use the front
panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the TONE button, press and hold the STANDBY/ON button for about three seconds.
3 When you see RESET? appear in the display, press ENTER .
OK? shows in the display.
4 Press SYSTEM SETUP to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default
settings.
