SanDisk Sansa e260 MP3 Player Logo
Posted on Dec 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi i have the latest sanza fuse i put 50 songs on it and can see them when it is connected to the laptop but when disconnected it only shows 10 songs how do i find the other music i have downloaded?
Anonymous
Level 3:
  • SanDisk Master 32,281 Answers
  • Posted on Dec 09, 2010
Anonymous
SanDisk Master
Level 3:
Answers
32281
Questions
Helped
7905933
Points
102259
Are all the music files you copied onto the MP3 player are in mp3 file format?
If not the player may be displaying only the mp3 music files.
Foe instruction on converting music and CDs into mp3 music files, please click on this link and follow my instructions :-
http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Hi when i dowloading the i tunes from the internet my ipod is connected to the laptop and after finshing the download the screen of the i pod doesnot appear when i coneect to the laptop its shows the...
1. If you have enabled AutoSync, everytime the iPod is connected, the iPod will sync all your files. It is not only the songs that are copied. It also copies the videos, photos and contacts too. Maybe it was trying to sync them.
2. Even if it had really done with sync of all songs, video, photos and contacts, it will always show the message "Do not disconnect". What you will have to do is click on the eject button in the iPod icon which appears in iTunes. The iPod will be ejected only when you eject it from the iTunes.
3helpful
2answers
PC wont recongize Sanza as a drive
You could try a reset?
Press and hold for 20 seconds the ON and PLAY (>||) buttons at the same time.
My sanza isn't reading any songs that i put on there anymore. I tried to delete the songs but it didn't work. so i tried to format it so i can free up all the space but it said format cannot be completed....
Okay are you talking about the internal memory or the SD disc?
If it is internal memory you could try a reset = Press and hold for 20 seconds the ON and PLAY (>||) buttons at the same time.
or
If it is the SD did you upgrade your Sanza to support Slot Radio? Slot radio does not use a file structure supported by Windows computer system.
Sansa 250c freezes at SanDisk and the Rat startup screen
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
1helpful
Deleted songs off my Sansa SanDisk and they are still there!
Use the Sansa Recovery Tool to start over from scratch.
-Tha Mp3 Doctor
Sony walkman nw-a3000
hi ali
it is comman problem , when u connect to pc , songs are played by song player of computer (like media player or real player) but latest version to play songs of the format is present in walkman is there, due to lac of cd's , i suggest you to please go to Sony' website and download latest software of said modle & update , it will solve the problem
thanks
Sanza 2 gig
it sounds like you need to get a new battery. Your current battery might be strong enough to light the screen but not strong enough to launch the song. Thats only thing i can think of. Hope this helps! :-) please tell me if it does!
My e250 wont play some songs, they are marked as unknown
-Tha Mp3 Doctor
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
