Lack of maintenance.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
SOURCE: RUUD Heater and Ac MODEL #UGPH-07EAUER
It sounds like the thermostat is not functioning correctly. Has it been changed recently? I think the green wire is connected directly with red somewhere, maybe touching within the wiring in the wall. Also make sure the thermostat is set to auto not on. Sorry if you knew that but you would be surprised how many people don't.
SOURCE: Main burners don't come on, though the ignitor goes bright
you should hear a click ,its the valve opening ? of check to see if the air fiter is clean ,
SOURCE: sequencers keep breaking down on RUUD heat pump
the control voltage for the sequencer should be 24 volts. that needs to be checked. also the sequencer is a switch that allows current to pass through them and are rated at particular volts and amps. If you are having and overcurrent situation, then it may burn them up. this one is tricky because and overcurrent should burn up the fusable links at your heating elements first. I would have these voltages checked and make sure only one sequencer per heating element. the low voltage side may be wired in series but the line voltage should be parallel or not sharing the 240 volts
SOURCE: My minimax NT 400 heater will not ignite.
if none of the above don't work, put a brick on top of the vent, covering only about 1" of the vent, then try firing it up. if it works, then you aren't getting enough oxygen at the ignitor.
SOURCE: call for heat good induced draft
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Ok so here is a sequence of the heater lighting and the solution for your problem...
1. Thermostat calls for heat.
2. Draft inducer motor starts.
3. Pressure switch attached by a small plastic or rubber tube senses the negative pressure produced by the draft inducer and closes.
4. Draft inducer runs for 30 seconds to a minute before you hear a gas hissing sound. The ignitor did not glow, the flame sensor (a small metal probe about 1/8" in diameter, with a white porcelain base) does not sense the flame, so after 8 to 10 seconds the hissing sounds stops with no ignition of gas to heat your home. Your furnace shuts down and goes into a lock out condition until you turn your power switch back off and on again. Then the sequence starts all over again with no ignition of the gas.
Solution:You probably need to purchase and install a new ignitor. I would suggest that you inspect your ignitor closely for cracks.Make sure you do not touch the ignitor with your bare hands. If you do not visually see a crack, then you could have a furnace control board problem or a limit, rollout switch problem. Please see "limits, rollout switches & furnace control boards" further down on this page. The furnace's control board might not be supplying the voltage to the ignitor. If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning. Please see the pictures below to help you identify a flame sensor.
Thanks and I hope this helps. Feedback apprec.
1.
2.
3.
closes.
4.
ignitor closely for cracks. Make sure you do not
limit, rollout switch problem. The furnace's control board
might not be supplying the voltage to the ignitor.If your furnace
1.
2.
3.
closes.
4.
gas.
Solution: You
inspect your ignitor closely for cracks. Make sure
problem or a limit, rollout switch problem. The furnace's
gas.
Solution: You
