On srartup Keep hitting F9 until restore screen pops up.Follow instructions (Your Choice Of Partions).2 partitions puts it back to factory, and you can start off like new.
Just on phone with ASUS rep. We're getting error on boot on a new unit. Told me to remove battery and power line and hold down power button for 30 seconds then plug in power (not batt) and press power then immediately press F9 again and again until a recovery screen that would reinstall from partition on hard drive appeared. Sadly, F9 didn't work for me and its off to service dept with a brand new unit that worked for 2 hours. Not so sure about ASUS. Have Compaq, HP & Toshibas with only one problem Toshiba within first year of purchase.
Click the "Start" icon on the Windows Vista home screen. Select "eMachines," then click "eMachines Recovery Management." The eMachines Recovery Management program opens.
Click "Create Factory Default Disc." The program will tell you how many discs you will need. Make sure the correct optical drive is selected, then insert a blank disc into that drive. Click "Start" to begin the burning process.
Remove the disc when it is finished burning and label it "Recovery CD 1." Insert the next the next blank disc if one is required. Click "OK" to begin burning the next disc. Repeat this step until all of the discs have been created and labeled. Close the eMachines Recovery Management program, insert the system CD that came with the laptop and restart the laptop.
Press "F12" repeatedly when the eMachines logo is displayed on the screen to be redirected to the Boot menu. Select the optical drive, then press "Enter."
Insert Recovery CD 1 when you are prompted to insert the recovery disc. The eMachines Recovery Management program will open.
Click the "Restore" tab in the list on the left side of the eMachines Recovery Management program window, then select "Completely Restore System to Factory Defaults." The computer automatically restarts and the recovery process begins. Insert any additional recovery discs as requested. The computer will reboot automatically when the laptop has been recovered to its original factory default settings, and you will be taken to the Windows Setup screen.
Set up Windows Vista with your own personal settings.
