SOURCE: Red blinking light, SONY KV-32FS13
The 4 blinks usually mean a vertical deflection problem. If you can solder you should be able to repair this yourself. Let me know if you wish to attempt the repair and I'll provide more details and instructions.
Dan
SOURCE: Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
SOURCE: sony mod# KV-34HS420 - won't come on - red led blinks 7 times...
how many times does the light blink it is very important you mention it so that i can be able to help you.if it is blinking continously then that means your jungle ic301 the ik video path is defected have a tech look on your set for repairs,good luck
SOURCE: Sony KV-34HS420 shuts of and stand-by light blinks
blinking 7 times after shutdown and after 3 sec repeats the same number of blinks.possible cause is over voltage at horizontal deflection circuit,or over voltage at power supply, or high voltage leak at FBT,or FBT itself is defective.open resistor related to ABL circuit.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
Source
